injectors, headstuds, and head gaskets.
Old Apr 10, 2008 | 04:50 PM
stacking's Avatar
stacking
we're putting new head gaskets in my truck. we're on the passenger side on the last injector on the back. we're having a little troubble geting it out with the air conditioner box thing in the way. for those of you who have taken injectors out, how do you get that last injector past that plastic ac box?
thanks,
stacking
Old Apr 10, 2008 | 05:59 PM
FARM69's Avatar
FARM69
Take the box off. I think there was only one bolt holding it on. Somewhere on the front midway down if IIRC.
It's basically just a plastic shield.
Old Apr 10, 2008 | 06:02 PM
Cuda_jim's Avatar
Cuda_jim
I think if you remove the insulation on the HVAC box you can remove the small vacuum tank mounted on the side, giving you enough room to get the injector out.
Old Apr 10, 2008 | 06:03 PM
Cuda_jim's Avatar
Cuda_jim
Geez, Am I slow at typing or what? Farm has it covered.
FARM69's Avatar
FARM69
Thanks for the correct termonolgy cuda!
I couldn't rememeber for the life of me what it was actually called.
Old Apr 10, 2008 | 08:52 PM
FARM69's Avatar
FARM69
Lol Cuda... Your not getting slow, I'm just getting faster!
Stacking, did you get that injector pulled?
Old Apr 10, 2008 | 09:28 PM
IceboxFX's Avatar
IceboxFX
hey i was working with stacking on the truck tonight..
we didnt get a chance to check back on here tonight so we will work on getting that ac box off tomorrow. thanks alot for the help farm & cuda.
we did get all the rocker arms, pushrods, and all of the other injectors and head bolts out on that side and the drivers side. things are going pretty smoothly so far.
while we are in there we are gonna do the head studs and injectors, then probably a new turbo when he gets the money. we're gonna go with the DIY's.
what do you guys reccomend to do for prying the heads loose?
-brian
Old Apr 10, 2008 | 10:03 PM
FFemt5287's Avatar
FFemt5287
there was a thread a few weeks ago about pulling heads and i think it was suggested that a big flathead screwdriver be used. im sure uve already done ur homework, but dont forget those suckers weigh about 130# each. what stage diy's are you doing that youre studding the heads? good luck n dont forget to do a writeup when you're done!
-Brandon
Old Apr 11, 2008 | 10:29 AM
FARM69's Avatar
FARM69
I'm curious as well. Is he putting in stage 3's or hybrids? IIRC the stock headstuds are good for about 45 lbs of boost.
Old Apr 12, 2008 | 10:56 PM
lukecline's Avatar
lukecline
are the head gaskests popped or what???? if they are nto blown just replace the bolts with studs one at a time. torque to 90-95 lb/ft then after you get all the studs in go back and tq them to 115 and final up to 130- 135 lb/ft. If a head gasket is blown pull the engine and replace the connecting rod in that cylinder.
Old Apr 12, 2008 | 10:58 PM
lukecline's Avatar
lukecline
stock head bolts! studs are a stud with washer and nut- stock bolts are just that... bolts.
Old Apr 13, 2008 | 02:26 AM
immastrokinnow's Avatar
immastrokinnow
WHAT?
Old Apr 13, 2008 | 06:50 PM
lukecline's Avatar
lukecline
Originally Posted by immastrokinnow
WHAT?
When you blow a headgasket there is a chance that the engine can hydralock and bend a rod. It is a rule of thumb that you replace the connecting rod in the cylinder that blew the hg, otherwise if you just stick it back together you risk a rod leaving the block down the road.
Old Apr 14, 2008 | 12:29 AM
immastrokinnow
i did not know that. but then again thats why I, and im sure the rest of us are on this site. is to learn from some and teach the others. thanks
