Man vs wood chipper
Well said.
I guess I have to be the devil's advocate here.
If the guy had used the proper safety precautions and -
1) not force-fed the chipper
2) trimmed the branches before feeding (he might not have been caught/trapped in them).
3) had someone else there to assist
4) had used his head and thought about the task at hand. (Job complacency!)
I don't care what job you have. . . from sitting behind a computer all day, to baker, truck driver, printer, police officer, overhead lineman, chipper/shredder operator, automotive technician, etc., etc., etc., Safety MUST BE job #1.
If you keep your hand on the safety handle while feeding the branches while near the machine, if you get pulled in, the machine will reverse feed. I usually like to work in a two man team. I keep my hand on the safety handle, the other person gives the limb and I feed. That way I do not worry about a stupid home owner or hired help killing themselves.
Some debate on it, but, I think feeding butt end first is the safest. You can break away from an entrapping small branch, if your glove gets caught on a 3" limb you are going for on a ride.
The other problem is people feed from directly back or feed uncut limbs that are awkward to feed. Uncut limbs are probably the biggest hazard because they can whip you or pull you in.
The only way I want to feed the 14" chippers is with a Bobcat, the 6" ones are pretty safe as long as you don't do stupid.
He decided I should work by myself.
and all chippers have warning labels all over them to not force feed the unit. but every year, we read about someone getting run through the chipper because of poor judgment while operating it, or disregard of the safety features put in place to keep accidents just like this from happening.
Machinery is designed to work in a specific manner, equipped with all safe guarding along with being operated with in the manufactures operating capacities for the operators safety, as well as others working around the machinery.
I have known a few companies and individuals who trade safety for convenience on a daily basis, have also seen very smart people do some really dumb things, when operating machinery, always pushing the envelope for no logical or economical reason, most times nothing happens or they have a" near miss" nothing to serious, but luck always runs out at some point, and when it does run out, all you got left to depend on is those safety features you disabled.........
A short story of Laziness, Poor Judgment and Complacency
There was a really good concrete pump operator with 25 years experience around these parts,a few years back, who decided he didn't need to use his outrigger pads for that particular job since he was setting the pump up on asphalt, good bearing capacities, so he thought.... He set the pump up unfolded the boom stretched the boom out, primed the delivery system with concrete and started pumping the job, Once he got over the front left outrigger it punched through the asphalt, and the pump flipped over. Now this can happen with the rigger pads down but less chance of it happening because of the weight distribution on the footprint, so every precaution should be taken at all times to minimize this.
The worst part of this is, He had the boom over 3 Phase hydro lines each @ 8000V phase to ground, so now this just raised the stakes in the game of Roulette, when the boom a ( 42meter, 140' ft ) boom came falling out of the sky it crashed through the 3 phase lines and pinned a guy under the boom killing him instantly, blew the tires off the pump and started the hydraulic system on fire ( 800- 900 litres of hydraulic oil ) and electrocuting the ready mix driver at the back of the pump, who later died at the hospital.
What happened to the operator of the concrete pump? ...... well since he had a radio remote, he got to sit back and watch the show he had produced......
First mistake, Bad judgment booming over live Hydro lines...... That is a No No....... no exceptions to that rule...... IT'S THE LAW !
Second mistake, being lazy and complacent, accidents generally have the element of surprise, and usually come when you least expect it.... MURPHY'S LAW !
Now I'm not all that bright, .....but how does killing 2 people and burning up a concrete pump worth $ 1.2 million dollars for the sake of convenience to save 20 seconds work to minimize that risk seem logical or economical ?
