tailgate worth trying to fix?(PICS)
Old Apr 11, 2008 | 01:57 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
That's right, the holes are for the "Chrome" insert found on XLTs and Lariats.
Only OEM or licensed by Ford parts will have the Ford letters.
Old Apr 11, 2008 | 02:00 PM
uncle.stosh's Avatar
uncle.stosh
Those holes are optional and for the aluminum trim panel that goes in the middle (which I also have). I have an OEM one just like it on my truck without the holes.
I was going to put that one on my truck, but I found another mint one without the trim panel that I used instead.
I may just keep it and use it on my future "low rider" project.
Old Apr 11, 2008 | 03:21 PM
86F150302's Avatar
86F150302
how do you "open" them up to put the latching system and handle on them?
Old Apr 11, 2008 | 03:31 PM
uncle.stosh
Everything goes in from the ends or the outside. There is no reason to "open" them up.
Old Apr 11, 2008 | 03:49 PM
86F150302's Avatar
86F150302
Originally Posted by uncle.stosh
Everything goes in from the ends or the outside. There is no reason to "open" them up. P
outside meaning the sides?
Old Apr 11, 2008 | 03:59 PM
81-F-150-Explorer
That's right, through the sides.
Remove the tailgate handle bolts, and let it drop down. you will see two rods with plastic clips. Remove the rods from the clips and handle, and remove handle.
Remove the bolts from the latches on the side of the tailgate. Pull straight out the side. Latch and rod assymbly will come out in one piece.
It's really easy once you do it once.
Old Apr 11, 2008 | 05:41 PM
86F150302's Avatar
86F150302
o ok cool. Thanks
