changing 06 up pipe
Old Apr 10, 2008 | 10:00 AM
strokin71's Avatar
strokin71
changing 06 up pipe
Anyone tried this chaning the restritive up pipe 05-07 with the scoop to a 03-04 none scooped up pipe, not putting in the egr block platein, any difference ???? Was thinkin my 04 seem to have alot more *** than my 06 might be big part of it ????? scoop vs. none scoop
Old Apr 10, 2008 | 10:53 AM
GregsSD's Avatar
GregsSD
I've seen a pic of someone who just cut out the scoop (much cheaper). You can fit a sawsall blade in there far enough to just cut out the 05-07 scoop. I'm sure it would help because the scoop takes up about 1/2 of the up-pipe flow.
Old Apr 10, 2008 | 11:27 AM
doubledee715's Avatar
doubledee715
if you're gonna go through all the hassle of putting in the older up-pipe you might as well block off the cooler while you're in there, right?
Old Apr 11, 2008 | 02:04 PM
duffman77's Avatar
duffman77
Anybody got any pics of this?
Old Apr 11, 2008 | 05:38 PM
doubledee715
pics of what? up-pipes? You can see some on elite's website or just search google and you'd probably get a bunch of pics.
Old Apr 11, 2008 | 05:46 PM
HeavyAssault's Avatar
HeavyAssault
Old Apr 11, 2008 | 05:56 PM
duffman77's Avatar
duffman77
Thanks
How hard is it to take off being wedged in behind the engine?
Old Apr 11, 2008 | 10:04 PM
HeavyAssault
Small hands and skinny arms help quite a bit. I did it in the driveway with hand tools, especially extensions for the rachets. Removing the passenger wheel, and down pipe will help a bunch; some have removed the passenger wheel well liner as well
