Sponsored by: Real Truck
What does everyone use on their frame?
Old Apr 9, 2008 | 11:13 PM
stroken's Avatar
stroken
With my lift and all you can see my frame in my wheel wells clearly...What do you use to make it look a little better and hide the rust that isn't so expensive...everything I have tried as pealed off in a month or so.....
Old Apr 10, 2008 | 12:08 AM
jake00's Avatar
jake00
What have you tried?
Old Apr 10, 2008 | 12:17 AM
ReAX's Avatar
ReAX
I like Permatex's Heavy Duty undercoating. It comes in a spray can and never completely dries. So it's easy to touch up and will not chip.
Old Apr 10, 2008 | 12:46 AM
aldridgec's Avatar
aldridgec
The main reason it peels off is because of the original wax coating that came from the factory. To get anything besides rubberized undercoating to stick (even that will come off after a while) you have to clean the frame of the wax coating. Problem is, I don't know of a good way to do it. When I did mine, I tried everything from a torch or a sandblaster and the stuff didn't want to come off clean.
Old Apr 10, 2008 | 01:08 AM
ReAX's Avatar
ReAX
If it is wax, then dish soap should do the job of removing it. Dish soap can't tell the minimal difference between grease and wax.
Old Apr 10, 2008 | 06:59 AM
350z's Avatar
350z
Thumbs up
I used the undercoating that Eastwood sells ,it comes in spray or quarts , and brown or black , works and holds up great ,it is sort of a waxy type product like the frame has on it from the factory , Craig.
Old Apr 10, 2008 | 07:36 AM
stroken's Avatar
stroken
If tried spray paint of course, and I just tried duplicolor spray bedliner **** and that is now peeling off
Old Apr 10, 2008 | 08:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
I knew a guy who would just use the cheapest flat black spray paint he could get. He'd touch the truck up every time he washed it (which was often - typical mall crawler). It always looked good, if you like flat black frames.
Old Apr 10, 2008 | 09:07 AM
stroken's Avatar
stroken
yeah that would work, flat black would be fine, I just don't want to go through the hassle of painting it everytime I wash it..once sometimes even twice a week...
Old Apr 10, 2008 | 11:40 AM
DAVE67FD's Avatar
DAVE67FD
If you wan't to do it right the first time I would spray coat the entire frame with Simple Green. Let it soak and high pressure spray with hot water. Once dry remove any old and flaking paint/rust (my assumption is that you mentioned rust so i would guess you don't have to much or any wax on the frame) with a wire brush the best you can. Clean again with the Simple Green and rinse thouroughly Then coat with a high quality rust preventer like some of the Por materials from Eastwood or equiv.
Old Apr 10, 2008 | 01:39 PM
stroken's Avatar
stroken
http://www.eastwoodco.com/shopping/p...ProductID=1113
Is this what I am aiming for?
Old Apr 10, 2008 | 04:04 PM
350z's Avatar
350z
Arrow
Look under Eastwood branded products , look for heavy-duty anti rust.
Old Apr 10, 2008 | 07:31 PM
high ho silver's Avatar
high ho silver
I coat mine with the stuff I put on my tires to make them shine. What ever I happen to have bought from Wally World.
Old Apr 10, 2008 | 07:46 PM
rudedogii's Avatar
rudedogii
Hey guys when I want my trucks to look real clean I spray the frame and axels with WD-40 and let it dry.
Old Apr 10, 2008 | 08:53 PM
Heff-7.3PSD's Avatar
Heff-7.3PSD
I have good luck with the 3M professional undercoating in a spray can. Wal-mart or auto parts store $7 or 8 bucks.
