RPM's at 70
Old Apr 9, 2008 | 10:00 PM
mudslingur's Avatar
mudslingur
RPM's at 70
With my 35's on my truck my truck is a turd,it takes for ever to pick up speed.
Well last week I put on some 31's so it would fit in the garage,well i took it out and with those doughnuts on my truck it is able to pick up speed fast and mabye even "halls ACE."
So I need to regear,and was just wondering what rpms yall turn at highway speeds.
Thanks guys
Old Apr 9, 2008 | 10:02 PM
78f-150Supercab's Avatar
78f-150Supercab
With 2.73 gears w/ 29" tires I pushed around 2300 rpm at 70 mph.
Old Apr 9, 2008 | 11:03 PM
brandon75_390's Avatar
brandon75_390
with 34"s and 4.10's, I am running at 3000 rpm between 65 and 70 mph
Old Apr 10, 2008 | 01:15 AM
montana_highboy's Avatar
montana_highboy
With 235/85/16's (31" actual ride height) and 4.11's i turn 2900 rpm's @65mph.
Old Apr 10, 2008 | 08:47 AM
FE406's Avatar
FE406
here's two formula's for you to calculate what your present or expected rpm will be if you are wanting to change tire and or gear size:
RPM x tire diameter divided by final gear ratio x 336 = MPH
example: 2600 RPM x 35 (tire diameter)=91000
4.56 (final gear ratio) x 336=1532.16
91000 divided by 1532.16=59.39 MPH
or:
MPH x final gear ratio x 336 divided by tire diameter=RPM
example: 60 MPH x 4.56 (final gear ratio)=273.6 x 336=91929.6
91929.6 divided by 35 (tire diameter)=2626.56 RPM
dont forget you need to calculate your final gear ratio by knowing what your trans ratio at its highest gear is. most are 1:1, but say if you have OD you would first multiply the OD ratio x rear axle ratio ( example .80 x 4.56=3.65) to calculate your final gear ratio.
walt
Old Apr 10, 2008 | 10:18 AM
tbear853's Avatar
tbear853
Mine has 31/10.50-15s and stock 3.50 gearing, C-6 and it turns up about 2700 at 70 as I recall.
You pay a big price for those big tires every mile you drive.
Anytime you put larger diameter tires on you are going to slow acceleration for several reasons, more rubber and belt (takes more to wrap a larger circle) and the fact that this added weight,plus the weight of the added sidewall is all added on a larger circle, which has to be spun up from lower speeds. Once up to speed, it all takes greater effort to slow down as well as it has greater momentum. The bigger tires, greater weight, also change direction less willingly due to a greater gyroscopic effect.
Imagine taking a 2 foot 2x4, grasping it in the center with your right hand, and twisting it in circular fashion back and forth like a propeller. Now do it with a 3 foot piece of 2x6.
Old Apr 10, 2008 | 10:49 AM
85e150's Avatar
85e150
Scroll down to second calculator. Just because the tire SAYS 31 inch don't mean it is. Check your loaded radius with standard air pressure. 1 inch doesn't make much of a diff.
37s and 4.56s...seems off unless you have OD.
Novak Conversions - Gearing & Gearing Math for Jeeps
