Sponsored by: Real Truck
Itchy hands trying to do mods again!
Old Apr 9, 2008 | 08:05 PM
Vijay's Avatar
Vijay
Hey guys,
I ‘m looking to buy four after-market gauges for my 7.3.
I had bought a four gauge pillar mount (a year ago…now that I’m digging my storage for space and I keep finding things that I bought for my truck but never got to installs them, a pair of semi truck wheels too!)
I have sorted three gauge until now, namely: 60 PSI boost gauge, exhaust temp, transmission temp and forth one is open for options………..???? any ideas?
Old Apr 9, 2008 | 08:35 PM
Toyman's Avatar
Toyman
I would probably go with rear axle temp. But you could also do engine oil temp.
Toyman
Old Apr 9, 2008 | 08:37 PM
redford's Avatar
redford
FTE Leadership Emeritus
Voltmeter - Oil Temp - Fuel Pressure - Air Pressure (for when you get a train horn) - Ammeter
Old Apr 9, 2008 | 08:39 PM
jimmyb08SD's Avatar
jimmyb08SD
cyl head temp
Old Apr 9, 2008 | 10:12 PM
TNT in Round Rock's Avatar
TNT in Round Rock
fuel pressure
Old Apr 10, 2008 | 01:40 AM
orng1's Avatar
orng1
Originally Posted by TNT in Round Rock
fuel pressure
I've been thinking about a fuel presure gauge too. Is it worth it?
Old Apr 10, 2008 | 04:08 AM
tex25025's Avatar
tex25025
I would say that it is important, but not as important as water or oil temp(no need to go thru that debate). These injectors don't like being starved for fuel and if you do something like the Fuel Regulated Return I would have a gauge in the cab for fuel pressure as that could be taxing to the stock fuel pump depending on how high you raise that pressure and you won't know it til your injectors start going on you because the fuel pressure gauge that comes with the kit goes underneath the hood and that doesn't do much good unless your changing the pressure or just have the hood open with the engine idling for some reason.
Old Apr 10, 2008 | 07:15 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
That last spot would be a great place for a DP Tuner switch!!
Old Apr 10, 2008 | 08:43 AM
UP_There's Avatar
UP_There
Originally Posted by Vijay
Hey guys,
F5 switch for the DP Tuner!
Old Apr 10, 2008 | 12:03 PM
Vijay's Avatar
Vijay
oil temp gauge it is....
Old Apr 10, 2008 | 12:05 PM
Vijay's Avatar
Vijay
BTW, What is the difference between the temp gauge ( stock ) and oil temp gauge? What temp is the stock gauge that came from factory measure?
Old Apr 10, 2008 | 12:11 PM
LSAtexan4x4's Avatar
LSAtexan4x4
coolant , its the water temp..... id go with fuel pressure but i dont wanna change your mind, id like to know for sure that my fuel pumps are giving the injectors sufficient fuel
Old Apr 10, 2008 | 12:42 PM
tex25025's Avatar
tex25025
Like what was already said it is to measure water temp(coolant). Now the oil temp gauge should read about 20-25 degrees higher then water temp should(most of the time people would see 195 on water temp so that would be round 215-220, now there are alot of variables that come into play here, but I would say that would be round the average). Be the way, the coolant temp gauge isn't a good gauge to go off of either unfortunately. You would think that with as much money as people pay out for these trucks that they would have the display be accurate, but nooooo. Might as well not have put them on there in all honesty.
