Thought I would ask a question about the timming mark on my dampner. I have it off the truck, and have read here a couple times that others had found that the timing mark wasn't where they expected it to be with the gears all lined up. It's going to be a while before I am ready to put the front end back together so I thought I would ask here to find out what others have seen.
So, I measured the angle between the slot for the woodruf key, timming it to the crank, and the groove that indicates TDC. I get 110°.
Anybody else ever measured this or know what the factory spec would be?
Thanks for the article link, I'm pretty comfortable with the setup but am always open to new information. I was more interested in whether anybody had ever actually measured the angle on the dampner.
When I get around to reassembling the front of the motor I can check it easy enough. I was just curious if anybody had a spec or had ever measured their dampner for comparison.
Dawdddlings of the dimented mind.
its a valid question , the outer ring of the damper will slip on the rubber isolator it is mounted on over a period of time ,and result in inaccurate timing marks
That's why I asked the question. If nobody else has measured it maybe I'll be able to actually contribute something. When I put the front back together I'll have the gears all lined up and be able to measure and record any variation.
thats would be excellent because my balancer has crawled and i do not have a known good one to compare for the correct orientation of the marks versus the keyway ,if i had the information i could compensate for it and use my timing meter to set the pump
How many miles do you have on your engine? Mines at 180K
My engine had been so poorly maintained by the PO that I have bigger questions than timing. When I pulled the injectors one of them was corroded so bad that I'm sure that it had been a long time since it had worked at all.
I'm going to put it back together the best that I can and hope for the best. My gamble is that the engine is stronger than the PO was stupid. This truck sat outside in Western Oregon rain for long periods of time and then he drove it like a gasser, quick start and go, then let it set for a while again. If it starts and runs good, I win, if not............
I would say if all the right marks that we use to align the gears are correct and the Harmonic balancer is showing as moved........ I would order a new one.........I have seen too many car HBs rattling around on the crank all worn out.
Have to admit that I hadn't thought of that. So, If I'm understanding your point, if the timing mark is off then the fit to the crank is suspect enough to warrent replacement.
Oh well, what's another $140, the way things are going it isn't much more than filling both tanks with fuel.
