Dtc P0401
Old Apr 9, 2008 | 07:43 PM
vicv's Avatar
vicv
Dtc P0401
Insufficient EGR flow...from what I've read it's common to the DPFE failing. I replaced it this evening and will see if the code comes back. Can I expect better mileage if the DPFE was the culprit for the code?
Old Apr 20, 2008 | 10:34 AM
osheam's Avatar
osheam
MAF sensor
Try cleaning or swapping out the Mass Air Flow sensor; located in the air intake system; normally between the air filter and the engine. Had the same problem with my old '97 XLT. Cleaning the MAF solved the problem temporarily however replacing the MAF solved the problem permanently.
Old Apr 21, 2008 | 09:14 AM
vicv's Avatar
vicv
Thanks for the reply...I had replaced the MAF (IAC too) about 1.5 years ago. I took the old DPFE apart to see what was inside, it was full of crud. Since I replaced the DPFE the CEL has not come back on.
Shakina Glory
4 Cylinder Engines
Oct 28, 2019 03:18 PM
little_mule
Modular V8 (4.6L, 5.4L)
Jun 3, 2012 09:49 AM
deejdeej
1983 - 2012 Ranger & B-Series
Jun 10, 2010 09:51 PM
blieux1
1997 - 2003 F150
Feb 24, 2007 11:14 AM
jrebel
Oct 12, 2004 09:16 PM
