Lights not steady
Old Apr 10, 2008 | 11:20 PM
rmalottwtes30's Avatar
rmalottwtes30
Just throw a ground everywhere?
engine to cab? cab to frame? bed to frame?
Where else needs a ground?
Old Apr 10, 2008 | 11:40 PM
ford trans tech's Avatar
ford trans tech
engine to cab and to right hand fender
engine to frame
frame to bed
Old Apr 11, 2008 | 12:38 PM
BIG R's Avatar
BIG R
Originally Posted by ford trans tech
there were two different volateg regulators one if equipped with an ammeter the other for a light only , but both are replaced with a single replacement regulator so dont be alarmed if the new ford regulator looks different , i bought mine at napa
you wont be able to find one at a dealer they have long since discontinued them
also see if the ground wire to the body of teh regulator is corroded and a bad rectifier in the alt. will cause the pulsing
if you have a DVOM set it to A/C voltage and probe the battery while its running if you get a reading on A/C scale the recitifier has one or more bad diodes
Huh, my dealer still stocks them. part number fopz10316a. I bought mine there less than a year ago, called today and they still have two in stock.
Old Apr 12, 2008 | 06:14 PM
ford trans tech
no one , in the DFW metroplex stocks them because everyone buys from the auto parts store
i work in a dealer and more parts than you might think have been obsoleted by ford
Old Jan 1, 2009 | 10:08 PM
Mallardman007's Avatar
Mallardman007
Was your pulsating light issue resolved? If so can you shed some light on what it was? My truck has in internal regulator and I have replaced the altenator twice and still have the pulsating lights.. Thanks in advance.
Old Jan 1, 2009 | 10:12 PM
rmalottwtes30
I never resolved this, after discussing this on the other diesel forums I am a member at, I came to the conclusion it is normal. The pulsating is just the glow plugs from when you first start the truck after it is started they still kick on and off a few times which is normal and they take a lot of juice to turn on and thus takes juice away from every where else. It does it even worse since I switched to the solid state glow plugs. After they do there cycle and all the lights stop flickering.
Old Jan 2, 2009 | 08:01 AM
Mallardman007
Thanks for the Reply. My Dad has an '89 IDI 7.3 that does the same thing as yours. My 99 does it now after I replaced the altenator except it is the opposite.... They dont start pulsating until 10 or so seconds after I start it up....
Old Jan 2, 2009 | 11:05 AM
starmilt's Avatar
starmilt
They shouldn't pulse very long after you crank it sometimes that is a sign of a controller going on the blink.
Old Jan 2, 2009 | 12:20 PM
82F100SWB's Avatar
82F100SWB
My 6.9 truck developed pulsating lights not too long after I replaced a dead alternator. I tried another new alt, nothing, I tried a new regulator, and made sure everything was grounded properly, still the same. What it turned out to be was one of the connectors in the regulator plug was loose, replaced the connector, and all is well.
Old Jan 2, 2009 | 02:13 PM
79f150toy's Avatar
79f150toy
My truck's lights and voltmeter pulsated for about 18 months...put new VR and it turned out to be a bad diode in the alternator...I put another alt in from a salvage yard and it has cured the many charging probs I had(my voltmeter inthe cab would fluctuate and seem to wag like a dog's tail...weird)...however, the only prob was that the wire conection was 180 degress from where they were on the truck, so I had to take the case apart and rotate the case 180 degrees(which was a pain trying to get the brushes in the holder)....
Old Jan 2, 2009 | 09:33 PM
WAExplorer's Avatar
WAExplorer
I had a 91 Explorer that did that. I was told it was the headlight switch. Never replaced it, sold the truck. Pulse would go away when alternator was full fielded. But pulsed constantly at idle.
