Big time oil leak! help
Old Apr 9, 2008 | 01:37 PM
crack's Avatar
crack
ok, my hpop is leaking again somewhere I think. I had a leak a number ofm onths ago and its not comming from that plug...the oil is pooling in the valley and then when I park somewhere it just dumps all over the ground by the tranny....any ideas where to start looking?
Old Apr 9, 2008 | 01:58 PM
PaysonPSD's Avatar
PaysonPSD
If you have checked the plugs on HPOP then check the HPOP lines at the HPOP and at each head as well as along the length of each line. Most common leak of the lines are o-rings at the HPOP or where the lines connect to the heads. Also look at the back plate of the HPOP. Back side of rear plate is sealed with an o-ring.
