Starter...???
Old May 29, 2002 | 06:55 PM
TheWiz427's Avatar
TheWiz427
Starter...???
Old May 31, 2002 | 04:23 PM
FelonyHunter's Avatar
FelonyHunter
Starter...???
Will the starter used on a 460 work on a 341W...?
I know the bolt pattern is the same on the transmission plate, but is the throw the same length...?
Old Jun 2, 2002 | 08:03 PM
sauerf100s's Avatar
sauerf100s
Starter...???
It depends. Some standard transmissions used different throw starters then automatics. All automatics use the same throw starter.
Old Jun 3, 2002 | 10:46 AM
FelonyHunter
Starter...???
Thank You...
I used the same transmission (C6), but had to change the case to fit a small block...
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
