Pushing coolant through cap
Old Apr 9, 2008 | 06:20 AM
Tim98TA's Avatar
Tim98TA
I have been having an issue with my '05 PSD pushing coolant through the coolant tank fill cap. The other day cruising on the interstae it started running hot, then would immediately cool down. It kept on doing this for about 2 hours. I ended up having to put about 4 gallons of water in it for that period. On the 4 hour return trip, I had absolutely NO issues. I even ran the ac for half the trip. This am, I got out of the truck after driving to work and I had coolant in the fenderwell again. It didn't run hot though. My first thought was a head gasket, but if I turn the truck off and let it sit for a bit, I still have pressure in the system. I'm thinking maybe a sticking thermostat, or maybe a bad coolant tank cap.
Anyone had any issues like this?
Old Apr 9, 2008 | 09:21 AM
rbloodhound's Avatar
rbloodhound
It could be bad head gaskets, or egr cooler.
How many miles on your truck? If it is under warrenty I would take it in.
Old Apr 9, 2008 | 10:23 AM
Tim98TA's Avatar
Tim98TA
Have 54,000 miles.
I thought head gasket, but with it holding pressure after the truck is off, kinda ruled that out.
EGR cooler huh? Easy to change or best done by dealer?
Old Apr 9, 2008 | 11:11 AM
MeyerzF350's Avatar
MeyerzF350
Search +coolant +puke. Mine turned out to be EGR, EGR cooler and head gaskets. Hope to get it back today from the dealer.
Old Apr 9, 2008 | 12:34 PM
Kep4's Avatar
Kep4
Jäger
What level do you keep the coolant at? It should be at the 'Min' level or it's likely to puke as well.
I was also told by a Ford parts guy that the cap should be replaced if it's been puked through more than once. Is it true? Dunno... but I replaced mine!
Old Apr 12, 2008 | 08:08 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Agreed with Kepler, my truck had puking issues when I first got it, GREAT, huh? Turns out thanks to this site the degas bottle was overfull, sucked out the required amount of coolant and I got a new cap also. No more puking. Maybe I was one of the lucky ones
Old Apr 13, 2008 | 11:18 AM
Kusto's Avatar
Kusto
If you are off warranty, check the level and get a new cap. If the condition persists take two aspirin and call your service department in the morning. Otherwise go in and get the test done to see if there is excess pressure being built up in the cooling system.
Old Apr 13, 2008 | 03:22 PM
brentos's Avatar
brentos
You have bigger problems than a bad cap if you loose 4 gallons of coolant. Check your egr cooler or egr valve it sounds like the cooler is clogged and is flash boiling, that is why it still holds pressure. take it in and have it replaced or delete the hole egr system completely.
Old Apr 13, 2008 | 09:01 PM
Tim98TA's Avatar
Tim98TA
Well if I get it to about 17psi of turbo boost, which is 1 psi higher than the cap rating, then it pushes fluid. I can go all day long with out running it hard and it is fine. How hard is the EGR/COOLER to change? Where is it located on the manifold? I have an 8 hr trip tomorrw pulling my 5th wheel. I KNOW I will have problems if I don't get it fixed. Dion't have time for a dealer to screw around with it.
Old Apr 14, 2008 | 06:10 AM
Tim98TA's Avatar
Tim98TA
Anyone got any ideas?
Old Apr 14, 2008 | 11:13 AM
tippmann87's Avatar
tippmann87
The turbo's boost pressure has nothing to do with the coolant cap's rating. IMO it sounds like head gaskets and possible EGR/cooler. I would take it in and let the dealer deal with it. Ask if you can provide head studs and have them put them in for you to prevent HG problems in the future. When I had blown HG's, as long as I was easy on the throttle, I wouldn't puke that much. How much weight you plan on moving?
Old Apr 15, 2008 | 07:39 AM
Tim98TA's Avatar
Tim98TA
Originally Posted by tippmann87
The turbo's boost pressure has nothing to do with the coolant cap's rating. IMO it sounds like head gaskets and possible EGR/cooler. How much weight you plan on moving?
Well the turbo boost and cap problem ARE kind of related. If the turbo builds boost up to and above the caps pressure rating, it pukes. If I drive it below this, it NEVER pukes.
I don't think it's a head gasket. If I turn the truck off, and let it sit for a bit, the coolant system is still holding pressure. A blown head gasket would allow it to bleed down along with some coolant in the exhaust and/or oil system.
Where is the EGR cooler located on these engines? Top or back of the manifold? Can I just unplug it to test the theory? I would imagine that it is electrically controlled?
Old Apr 15, 2008 | 10:14 AM
w_huisman's Avatar
w_huisman
Talking
It's amazing what you can find by spending just minutes using the search feature and poking around the TECH FOLDER located at the top of this forum.
Old Apr 15, 2008 | 11:56 AM
DSMMH's Avatar
DSMMH
I have a similar issue with mine and instead of paying the dealer to GUESS I went on the net and got a Gas/Diesel Combustion Gas Test Kit for about $45. I tested and retested the cooling system under all conditions per the directions and more. Not a hint of exhaust gas in the coolant.
DSMMH
Old Apr 15, 2008 | 05:19 PM
Tim98TA's Avatar
Tim98TA
That helps for the basic operation of the EGR and the cooler, but it doesn't give me the location of them on my engine or tell me if I can simply unplug it to test to see whether or not it will fix my problem.
Anyone?
