oil drain plug torque
Old Apr 9, 2008 | 10:53 AM
HKusp's Avatar
HKusp
Dry as a bone. Not a drip or any residue on the Fumoto. I will say this. That little retainer ring took me a good 15 minutes to get it on(on the original install). I tried several times with Channel locks and several more with standard sized Vise-grips before I got it on. In fact, I told myself on the last try, if it didn't work that time, I was going to just say the heck with it.
Old Apr 9, 2008 | 12:26 PM
UP_There's Avatar
UP_There
My Fumoto came with a blue washer on it....seemed like it was a hard rubber material. My retainer ring was a PITA also! Kept popping out of the pliers I was gripping it with!!! lol I finally got it on about the tenth try
Old Apr 9, 2008 | 08:53 PM
GEugeneS's Avatar
GEugeneS
Thanks all. I just torqued it to 30 lbs and I'll let you know if that works. It was about 22 lbs before.
Old Apr 9, 2008 | 09:07 PM
Supercab's Avatar
Supercab
Wink
Mine is leaking a little as well-about a drop an hour.
It was completely dry until I changed the oil for the first time and put on a brand new copper washer!!!!
On Guzzle's site it says to get an M14 copper washer......which I did....IT IS BIGGER than the original copper washer I removed.
I saved the original and will get an exact replacement size to it for the next oil change....I think the M14 is too big...it is a little sloppy on the drain plug.
Old Apr 9, 2008 | 09:32 PM
GEugeneS's Avatar
GEugeneS
I replaced the old one with a brand new one too, but like yours, mine felt a little sloppy. What do I know, I just told the Kragen Auto Parts dude to get me a replacement. If torquing it to 30 doesn't work, I'm going to look for a soft washer.
Old Apr 9, 2008 | 11:01 PM
nhill2090's Avatar
nhill2090
the M14 washer with rubber middle worked out good for me at the auto parts store...it fit tightly, not loose like the ones described above
Old Apr 10, 2008 | 04:58 AM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Originally Posted by GEugeneS
Does anybody know what to torque the oil drain plug to? I have had a very slow leak there since i bought the truck a year ago. Changed the oil the last time and used the same copper washer and it leaked pretty bad. Got a tip on this forum how to hook up a shop-vac to the filler tube and pull the plug without losing any oil so I replaced the washer with a brand new one. Same thing. About 1 drip every hour or two. I can't visually see anything wrong with the seat or the plug.
I hear they are selling plastic washers now. Would that be a better way to go in case there is some small imperfection on the seat or plug I just can't see. Any ideas would help. Thanks. Gary
Gary:
I had the exact same problem when I first bought the truck. I found a hard plastic washer (AutoZone) to replace the brass one, and I have never had a leak since.
I just replaced it after 100,000 miles. The old one wasn't leaking, the pack I bought came with 2 (75 cents) and I figured I should finally use it before I lose it.
Hope that helps.
Good Luck.
Old Apr 10, 2008 | 09:02 AM
GEugeneS's Avatar
GEugeneS
Whitey,
I do believe we have an Auto Zone out here so I will try them. I just check my new copper washer torqued to 30 lbs and it's still leaking. thanks for the tip.
Old Apr 10, 2008 | 09:51 AM
Supercab's Avatar
Supercab
Wink
I wasn't aware that a copper washer (M14) was available with a rubber center ring......I'll bet that will do the trick!! Guzzle doesn't mention that rubber ring in his oil change procedure-just to get a M14 copper washer.
My original copper washer did not have any rubber center, but like I said before it did not leak at all before the change.
Old Apr 10, 2008 | 07:46 PM
GEugeneS's Avatar
GEugeneS
Well AutoZone had the plastic washer, but I found out why the leak too! My 2002 PSD truck uses a M14 "1.25" (19mm) hex plug with no flange to seat the washer. Basically, the plug looks just like a bolt! All the other M14 "1.50" plugs (with a much coarser thread) had a nice, big, round flange below the hex part to seat the washer.
No matter, the blue, plastic washer seems to be doing the trick. Thanks for all your help!
gary
Old Apr 23, 2008 | 01:59 PM
missouguy's Avatar
missouguy
Has anyone ever heard of the Fumoto being knocked off by hitting something like a rock?
Seems sort of vulnerable just hanging down under the pan.
Thanks
Frank
Old Apr 23, 2008 | 02:02 PM
UP_There's Avatar
UP_There
Thanks
Frank
Go outside and take a peek again at your drain plug.....there is quite a bit of damage that will occur before the rock ever gets that high to the Fumoto.
Old Apr 23, 2008 | 02:10 PM
  #28
missouguy's Avatar
missouguy
Yea, I guess you are right. It is an "off road" so there should be some protection under there.
Frank
Old Apr 23, 2008 | 04:32 PM
  #29
Whitey Ford
gary
Gary:
Mine is exactly the same. The blue plastic washer was the only thing that fixed it. I was paranoid the first 20k miles, checking it all the time. After that, I made it a total of 100k miles. I felt I should change it or lose the spare one. It never leaked.
Good Luck.
Old Apr 25, 2008 | 10:16 AM
  #30
GEugeneS's Avatar
GEugeneS
Whitey,
Been a week or two now and not a drip with the blue plastic washer. 'All I did was "snug" the drain plug up - very little tq. And yes, I have a spare. Funny, I'm not a big fan of plastic except in this case!
gary
Mcrafty1
Modular V8 (4.6L, 5.4L)
Jul 5, 2017 08:01 AM
NetCommuter
1997 - 2003 F150
Jul 19, 2009 06:42 PM
Bopper
Jul 12, 2009 08:00 PM
rmilchman
Jun 1, 2005 05:49 PM
bbb007
Escape & Escape Hybrid
Mar 4, 2005 08:12 AM
