Tips for spraying paint
Old Apr 8, 2008 | 08:35 PM
mudslingur's Avatar
mudslingur
I wanna start off by saying this forum has been a big help,and I'm about to complete my first paint job.I layed down the primer today,and am going to wet sand the primer tommorrow.
I am just looking to see if anybody has some tips for the next steps like spraying the actual paint(avoid running,flake control,anything),or any tips for spraying clear.
Also I am using the nason line of paint in this order (2k primer-ful-base basecoat-nason select clear),is there any tips or things that I should be aware of with this paint system
Thanks again guys
Old Apr 9, 2008 | 08:00 AM
385seriesHemi's Avatar
385seriesHemi
Well if you want a "show room" finish almost spray multiple layers of primer and block the hell out of it. If you do wet sand dont go any higher than 600 grit. When you spray the color do a 50/50 overlap and go the whole length of the panel not halfway and go back.
The gun should be about 8-12 inches away from the panel and dont tilt your gun either keep it parallel with the car at all times. I have never used Nason b4 so I cant tell ya how that sets up.
When spraying hoods & trunks spray the length of the lid and then change to a different cross pattern after first layer is complete. Do about 2 or 3 diff patterns going across the hood, roof (if possible) and trunk. You will have adaquately covered the area and have less of a chance of missing a spot.
Spraying clearcoat is almost the same as base but depending the clearcoat and temperature and humidity and how fast you are moving determines the amount of dripping or runs or orange peel will occur.
So make sure you have a place thats decently dry atmosphere if it is not a paint booth. But if you are painting in a GARAGE spray the floor down with water so no dust comes up into the paint and I suggest hanging plastic sheeting up around so you dont paint your other belongings at the same time.
Also whatever the paint manufacturer recommends for amount of coats I would add onemore to get the impurities out such as gauges n tiny dips. Primer is where the paintjob quality starts so if thats good your end result will be good also.
Eliduc
Paint & Bodywork
Mar 25, 2013 08:42 AM
Eliduc
Mar 19, 2013 06:41 AM
1983vf750f
Paint & Bodywork
Apr 4, 2004 05:57 PM
Rosati
Paint & Bodywork
22
Feb 16, 2003 10:51 PM
Rosati
Paint & Bodywork
Jul 16, 2001 11:39 PM
