Charging Problems
Old Apr 8, 2008 | 07:35 PM
rdmytro's Avatar
rdmytro
Charging Problems
I am having charging problems in my 88' F250 with a 7.3 IDI. Last week my alternator quit. Neither battery was charging. I got the alternator tested, it was over charging. I replaced both the alternator and the voltage regulator, and still the batteries are not charging. I am thinking something is broken in the wire harness. So before I How do I test the wiring? Has anyone replace with wireharness with a homemade overlay harness?
Old Apr 8, 2008 | 09:29 PM
PLC7.3's Avatar
PLC7.3
Check the white/yellow wire it is a fusible link.......also the connector is known to go bad. This is the wire that tells the alternator to charge or not.
Old Apr 9, 2008 | 05:20 PM
rdmytro's Avatar
rdmytro
The green wire on the other side of the fusible link was broken. Do I cut the fusible link out and solder the yellow/white, black, and green wires together. Should I put a replaceable fuse connector between the wires? If so, what amp should the fuse be?
Eric Quinn
23
Apr 29, 2013 06:42 AM
rob-o
Jan 29, 2009 08:32 PM
josh390
18
Nov 8, 2008 04:03 PM
tiger moth
Electrical Systems/Wiring
18
Sep 25, 2005 10:27 AM
rick
Jul 16, 2000 01:54 PM
