Cleaning water separator
Old Apr 10, 2008 | 12:58 PM
Das Ungetum's Avatar
Das Ungetum
I have the Racor set up and it worked real well on my 6.9. The older set up indeed put air into the system. The new mount also had a "primer" which helped when cahnging filters.
By the way, how often do most of you change these filters?
Old Apr 10, 2008 | 01:10 PM
rmalottwtes30's Avatar
rmalottwtes30
so the Racor Interceptor Fuel Filter just screws onto where my regular fuel filter goes?
Old Apr 10, 2008 | 01:18 PM
David85's Avatar
David85
Yes it will, but you will have to wire an external sensor if you want the "water in fuel" light to work. Same would be true if you went with a 7.3 style filter.
Old Jul 13, 2010 | 04:54 PM
Photobossman's Avatar
Photobossman
Water separator
Can you not just remove the pull ring bolt & replace with a regular bold to seal off this opening. Then place a valve at the bottom of the original Water separator unit?
I am not a Diesel expert so I am just asking will this not work?
Gary
Old Jul 13, 2010 | 06:36 PM
Rick Wallace's Avatar
Rick Wallace
Take it off and chunk it in the garbage,,,go to NAPA get part# 4309 and part# 3123 it will bolt up where the old one was then you are fixed..
Old Aug 27, 2020 | 07:26 PM
alod3794's Avatar
alod3794
What about the 3 prong sensor?
so let’s say I buy this kit with the filter.. what happens with the 3 prong plug? What will I need to hook that up to in order for my water in fuel light to still work?
Old Aug 28, 2020 | 11:26 PM
tecgod13's Avatar
tecgod13
What 3 prong plug are you talking about? The 7.3 IDI uses a single round right angle plug attached the water in fuel sensor on the bottom of the fuel bowl (or aftermarket filter when the sensor is swapped to the filter). The water in fuel sensor has a threaded contact where the plug goes.
Old Aug 28, 2020 | 11:35 PM
alod3794's Avatar
alod3794
Originally Posted by rmalottwtes30
Will it still leak air into the system since I changed all the rubber O_rings inside it?
what rubber o-rings did you replace the stock ones with and where did you get them from?
Old Aug 28, 2020 | 11:40 PM
alod3794's Avatar
alod3794
Just was wondering how buying the Napa kit, the light for the water in fuel would work
Old Aug 29, 2020 | 11:04 AM
Charmalu's Avatar
Charmalu
You dug up an old thread from 2008, this guy had not posted since 2012.
You will have a long wait for the answer.
Charlie
Old Aug 29, 2020 | 11:30 AM
alod3794's Avatar
alod3794
Charlie
just my luck! Lol
Old Aug 29, 2020 | 10:05 PM
Charmalu's Avatar
Charmalu
If you are searching and dig up an older thread, click on the user`s name, then "View public profile".
You will see the last time they were active.
There is good info in older threads, chances are a lot of those people have moved on.
Charlie
jollyrogr
6.7L Power Stroke Diesel
Feb 22, 2020 12:07 PM
kla94
Jan 13, 2015 10:48 PM
JonArmy
Sep 15, 2011 10:10 PM
audimaster
May 23, 2008 08:53 AM
