Sponsored by: Real Truck
offset?
Old Apr 8, 2008 | 11:46 AM
stroken's Avatar
stroken
offset?
I am confused on this... am ordering my wheels and tires as soon as I decide on wheels, moto metal 951 or diamo karat 17. from what I understand the 951's sit in, towards the spring and doesn't stick out very far...I tried to look at there offsets and all but I do no understand it....I want the wheel to stick out past the fenders some, but not a whole lot, can anyone help?
Old Apr 8, 2008 | 11:53 AM
DAVE67FD's Avatar
DAVE67FD
Here is a good link for wheel info. Hope it helps
Dave
https://www.rsracing.com/tech-wheel.html
Old Apr 8, 2008 | 11:57 AM
DCSpecial's Avatar
DCSpecial
Yep, that's a real good link for explaining offset and back space.
Old Apr 8, 2008 | 12:12 PM
stroken's Avatar
stroken
I got the measurements for the two I want and the ones I have..I think I got it figures out sort of.... Backspacing is what is getting me now, I understand offset, the ones I have now are 0 offset, and one of the new sets is -12 and the other is -18..that -18 will sit closer in towards the leaf spring then the -12 will..correct?
Old Apr 8, 2008 | 12:35 PM
Richard_cranium's Avatar
Richard_cranium
I'm not positive buit it looks to me like the higher - number offset the farther out and the higher positive number farther in.
That is saying that a 0 offset would be dead center of the rim
Old Apr 8, 2008 | 01:33 PM
stroken's Avatar
stroken
I thought the higher the - the closer to the spring it was...and the lower the - the further out of the fenders it was...and the 0 was dead center....
I hope someone chimes in soon and can help before I order!
Old Apr 8, 2008 | 02:24 PM
ben8892002's Avatar
ben8892002
i'm running 20x10's with 0mm offset and 275/65/20 goodyear wranglers. they stick out no further than my 285's on stock wheels. hope this helps
ben8892002's Avatar
ben8892002
no rubbing the leafs or the wheel wells either.
Old Apr 8, 2008 | 02:29 PM
DCSpecial's Avatar
DCSpecial
On Backspace, the higher the number the closer to the spring it is.
0 offset means that the wheels mounting surface is dead center in the middle of the wheel.
Offset varies based on the wheel width. The chart on that link does a pretty good job of showing what offset and backspace are at different widths.
On 99-04 trucks you want to stay around 4.5" Back Space....so if it's a 10" wide you'd want -25mm offset or so, if it's a 12" wider you'd want a -51 offset, etc..
05+ trucks you'd go any where from 4.5" - 5.75" back space depening on how far you wanted them to stick out.
Old Apr 8, 2008 | 02:30 PM
redford's Avatar
redford
FTE Leadership Emeritus
Negative offset: When the back of the bolt pad is closer to the inside of the wheel; when mounting surface is inboard of the rim centerline. Tires stick out.
Positive offset: When the back of the bolt pad is closer to the street side of the wheel; when the mounting surface is outboard of the rim centerline. Tires tuck in.
Old Apr 8, 2008 | 02:40 PM
stroken's Avatar
stroken
thanks a bunch guys!!!!
both rims are 20x10
so the -18 offset and the 4.79 backspacing will be tucked in
and the
one with the -12 offset and the 5.3 backspacing will be outside the fenders?
I think I got it right...
ONCE AGIAN I CANNOT THANK YOU GUYS ENOUGH!!!
sorrys guys, my truck is a 2003 f350..if that helps any
Old Apr 8, 2008 | 02:50 PM
DCSpecial's Avatar
DCSpecial
both rims are 20x10
and the
No, the 5.3" Backspace will be tucked in and rub on your leaf springs.
4.79" will stick out further (not a lot).
Old Apr 8, 2008 | 03:12 PM
stroken's Avatar
stroken
so it goes off the backspacing and not offset?
If I do not want it to rub my leaf springs I need to go with the 4.79 backspacing...
will either stick out past my fenders?
Old Apr 8, 2008 | 03:23 PM
DCSpecial's Avatar
DCSpecial
How far it sticks out is easier to figure out based on Back Spacing.
Offset will tell you back space and how far it will stick out if you know the width as well.
They each tell you where the mounting surface of the wheel is.......they just use different reference points to get the measurement.
The 4.79" B.S. on a 10" wide wheel will stick out a little.
As for rubbing the leaf springs, that will also depend on what size tires you go with.
Old Apr 8, 2008 | 04:31 PM
redford's Avatar
redford
The more negative offset, the more the tires stick out. -18 will stick out of the fenders more than -12.
Backspace (also called rear space in the image) is the measurement from the mounting flange to the inside lip of the wheel.
Offset is the measurement of the mounting flange to the wheel center line.
