Oil sending unit
Old Apr 8, 2008 | 10:50 AM
Scifi266's Avatar
Scifi266
Oil sending unit
Hey guys, I'm in the process of dropping in a 360 in my 66 and had a question. Its coming out of a 71 f250 and the p/o had placed a different style oil gauge under the dash. When I went to check the gauge it just has a line from the gauge to a spot right before the oil filter. so it runs right off the pressure. I was wondering if anybody could help me figure out how to set up the electronic gauge for my 66.
Old Apr 8, 2008 | 11:56 AM
jowilker's Avatar
jowilker
The electric and mechanical work from the same hole and either can be run. With a tee both can be run at the same time.
John
Old Apr 8, 2008 | 04:56 PM
Scifi266's Avatar
Scifi266
Is there anything I need to so the gauge would sense the pressure?
Old Apr 8, 2008 | 05:11 PM
jowilker's Avatar
jowilker
Yes, Either would have to have a sending unit. Which is on the engine now?
John
Old Apr 8, 2008 | 06:17 PM
Scifi266's Avatar
Scifi266
a Clear plastic tube that goes straight to the gauge
Old Apr 9, 2008 | 12:06 AM
frty7ford's Avatar
frty7ford
just replace the tube with the correct sending unit for the 66 and hook the wire up should work great.
Old Apr 9, 2008 | 04:25 AM
jowilker's Avatar
jowilker
If I reread you post correctly, you are wanting to add an electronic gauge, if yes the new gauge will have everything to replace the sending unit and hose.
John
Osiyo59
Dec 31, 2010 09:45 PM
Chevy 6.2D
May 14, 2009 02:49 AM
nealh.23
Apr 10, 2007 10:44 AM
dbrad4d
Dec 21, 2006 09:52 AM
Dads 66
Sep 12, 2005 11:58 AM
