questions about flipping
Old Apr 8, 2008 | 08:24 AM
f79truck's Avatar
f79truck
Question questions about flipping
I have a 95 f-150 2wd. I would like to flip the front I-beams but a couple of the guys and myself disagree on weather or not it will lower or raise the front end. I would like to lower so that's what I'm going for . any suggestions would be appreciated.
Old Apr 8, 2008 | 09:09 AM
Scndsin's Avatar
Scndsin
"If" it were mechanicaly possible,
It would raise the front end. The center of the spindle is higher than the lower pivot point as it sits. Your pivot angles would be wrong as well.
Hold your hand horizontaly in front front of you, looking at your palm. Think of your thumb as the spindle. Now flip it over. The spindle will get closer to the ground, the truck further away from the ground.
Hope this helps with your discussion.
Old Apr 8, 2008 | 09:18 AM
f79truck's Avatar
f79truck
Thanks, that helps a lot. since you are on a ball can you change the place of the spindle by sitting it on top of the the i beam hook up ( in theory flipping the ball joints like on the older foreign models ie.mazda, toyota).
Old Apr 8, 2008 | 09:28 AM
currituckF150's Avatar
currituckF150
The only way to properly lower our trucks is w/ lowered Ibeams. I used DJM dream beams for a 3" drop in front, belltech hanger/ shackle kit in rear for 4". Truck still is useable for towing & hauling. If that isn't enough do a flip kit for the rear(which is easier & cheaper to install) You don't need to C-notch frame just remove factory bumpstop & replace with smaller 1. Buy the best quality shocks possible(either Toxic or Bilstein).
Old Apr 8, 2008 | 03:17 PM
f79truck's Avatar
f79truck
Alright that's cool. I have heard that the new dream beams were bending on people or did they get that worked out. I had looked into them with my 79 ford but reports stated they were weak and not for daily use. I would like something that can still take a beating.
Stephen
95 F-150 4.9L
349943 miles
Old Apr 8, 2008 | 04:06 PM
currituckF150
I think that the bending part was a rumor starter by DJMs competition to sell more of their Ibeams. They are plenty strong. I've had mine lowered at least a year w/ no problems even holds proper alignment.
Old Apr 8, 2008 | 04:33 PM
StealthWyvern's Avatar
StealthWyvern
Currituckf150, I would like to see pictures of your truck on the DJM suspension! I'm currenly looking into this mod down the road. How would you raet the quality of their parts?
Old Apr 8, 2008 | 08:57 PM
StealthWyvern
bump for pics
skarpenz's Avatar
skarpenz
Just cut the front springs, I've been riding like that for...forever, and my tires don't even wear strange. I also flipped the rear with a DJM bracket. Make sure you get GOOD FRIGGIN SHOCKS when you do it, or you may just hate it.
Old Apr 8, 2008 | 08:59 PM
skarpenz's Avatar
skarpenz
The rear is lower now BTW, I installed my 1" shackles on top of the flip. I should have left it alone, lol.
Old Apr 8, 2008 | 09:12 PM
StealthWyvern
any side shots? Sorry but the javascripts or whatever it is that pops up when you click on a screen name doesnt work for me at work. lol
Old Apr 8, 2008 | 09:13 PM
skarpenz's Avatar
skarpenz
Let me run outside and get a better pic real quick. All low and stuff.
Old Apr 8, 2008 | 09:19 PM
StealthWyvern
wow thanks for a fast responce
Old Apr 8, 2008 | 09:27 PM
skarpenz's Avatar
skarpenz
There you go. I think it looks mean as hell, and it gets some looks. Especially when they hear the axle knock the frame a good one, haha.
Old Apr 8, 2008 | 09:29 PM
StealthWyvern
Did you have to change out your drive shaft or anything? I think I have a 2 peice shaft on my truck.
