fuel filter change?
Old Apr 7, 2008 | 08:00 AM
ramrod7373's Avatar
ramrod7373
fuel filter change?
This might be a stupid ?...but here it goes. I have never changed the fuel filter in my truck. Not sure how to do it. Do I have to drain the canister before taking the lid off? Or can I just unscrew the lid take out the old filter and put the new one in and screw the lid back on.
Thanks
Old Apr 7, 2008 | 10:26 AM
MagKarl's Avatar
MagKarl
I would say it would probably be smart to drain it first if the drain is clear. Remove the cap and see what's in there. You don't want crap getting in when the filter is removed, so drain the canister before you put in the new filter. When I bought mine the drain was stuck and plugged. I sucked it out with a syringe. Amazing how much crap was in the bottom of that canister. Then I rinsed it out with fuel once the drain was open.
Old Apr 7, 2008 | 11:04 AM
kawa's Avatar
kawa
Also, if there is a lot of crud in the bottom and you want to remove the stand pipe to get to everything the stand pipe is a LEFT HAND THREAD.
Use a crows foot to remove it.
Rog
Old Apr 7, 2008 | 11:06 AM
F700 Pickup_man's Avatar
F700 Pickup_man
How does one drain the cannister?
if I drain it and refill with fuel and new filter, do I have to prime it? or is refilling and new filter all it needs?
sorry to hijack
Old Apr 7, 2008 | 11:27 AM
kawa's Avatar
kawa
On the passenger side of the fuel filter there is a yellow lever that moves 1/4 of a turn. Turn the lever and hopefully the filter will drain. You should have a large container beneath the engine, front passenger area.
No you donot have to prime but if you have some clean fuel handy it's a good idea to pour some in the bowel with the new filter.
Rog
Skip1970
Mar 14, 2011 06:42 PM
Duck Hunter81
Apr 21, 2010 11:44 PM
Franko72
Apr 13, 2009 04:52 PM
edub32
19
Feb 13, 2009 12:24 PM
touchofgrey
Sep 14, 2005 02:21 PM
