stalling under braking
Old Apr 6, 2008 | 10:36 PM
cscott952's Avatar
cscott952
I've got an '85 302 EFI. When I disengage the clutch when braking, then engine occassionally stalls when dropping from highway engine speed back to idle. It never stalls unless I am braking. There are no codes, and the IAC/TPS seem fine. I cleaned both real well. There doesn't seem to be any wrong with the braking system either. Anything else to check?
Old Apr 6, 2008 | 10:52 PM
Franklin2's Avatar
Franklin2
While it's idling, disconnect the IAC. If the engine totally stalls out, turn the idle stop screw to open the throttle a little bit till the engine idles very slowly. Then plug the IAC back in and try it out.
Old Apr 7, 2008 | 11:02 AM
cscott952's Avatar
cscott952
Once all connected, should I back the idle set screw back out?
Jonnys.1991
Feb 9, 2015 04:31 PM
davidmolina
Jul 30, 2014 10:19 PM
fnx4wheeler
Dec 25, 2010 11:10 PM
alstieg
13
Dec 12, 2009 12:17 AM
Peltofskin
Apr 2, 2003 05:07 PM
