Sponsored by: Real Truck
Installing upfitter switches/brake controller
Old Apr 6, 2008 | 06:59 PM
QCIGUY's Avatar
QCIGUY
My father just picked up the upfitter switches and brake controller at an auto wrecker. We were wondering if all the wire harnesses are in the dash or does he need more than the dash mount pieces? Hoping he can just pop out the plastic and install.
Thanks in advance
Old Apr 6, 2008 | 08:19 PM
snake4712's Avatar
snake4712
The wires for the upfitters are behind the insulation but you can't install the brake controller without replacing the master cylinder. the brake controller is pretty advanced and responds to the amount of pressure sensed from the master cylinder instead of just when the brake lights go on like most.
Old Apr 7, 2008 | 10:33 AM
NorCalBusa's Avatar
NorCalBusa
You will also need the relay pack, that goes behind the glove box.
Old Apr 7, 2008 | 11:58 AM
redford's Avatar
redford
FTE Leadership Emeritus
You will also need your PCM reprogrammed for the Tow Command option.
Old Apr 7, 2008 | 12:22 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What year truck is it going into? A pre-'05 doesn't have a computer that is capable of recognizing the brake controller.
Old Apr 8, 2008 | 10:45 PM
QCIGUY's Avatar
QCIGUY
Thanks for the info. It is going into an 05. Does it still need all those things. I am sorry for not being specific.
Old Apr 8, 2008 | 10:52 PM
PowerStrokeHD's Avatar
PowerStrokeHD
Yes, even with a '05 you would still need the correct master cylinder and after the install it would need to be taken to the dealer for PCM reprogramming.
Old Apr 8, 2008 | 10:55 PM
QCIGUY's Avatar
QCIGUY
do you know about the relay box behind the glovebox that was mentioned?
