getting better MPG with 99 sd 7.3 turbo
Old 04-06-2008, 12:26 PM
pjpandhisnewtruck's Avatar
pjpandhisnewtruck
pjpandhisnewtruck is offline
Can anyone recomend a chipset / programer or whatever to increase my millage? Also, i've heard putting in an aftermarket turbo will help a lot as well. Any help here too?
pjp
Old 04-06-2008, 12:39 PM
jdecker88's Avatar
jdecker88
jdecker88 is offline
Well there is several things you can do. For starters get a 4 in exhaust or atleast cut out the muffler on your truck(if it is an early 99 look at gutting or deleting the cat) You can get a MKO exhaust for around 300 dollars without a tip he is one of our site sponsors. A Napa 6637 (along with a Pete filter cover)from fleetfilters.com they run around 32 dollars shipped I believe . A DP-tuner.com or a Tony Wildman chip is about the only way to go for programming these trucks. They are both equal chips for about the same price. A good set of gauges like Autometers or Isspros. Also check your tire pressure, change your fuel filter and clean your EBPS tube Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page.
Those are several common things to help get your fuel mileage up. Others will chime in if I missed anything
Old 04-06-2008, 12:59 PM
clintbonnie's Avatar
clintbonnie
clintbonnie is offline
You can get better fuel economy by just keeping your tach under 2000..Also, it is a good idea to read your fault codes once in while.. Might help find a sensor or other problem that might hurt your mileage..
Old 04-06-2008, 01:15 PM
zx250's Avatar
zx250
zx250 is offline
Of the next Riffraff East
The cheapest fuel saving mod it a 2x4 block. Cut it about 2.5 inches long and screw it to the back side of you acc. pedal. Other than that, the above suggestions work. If you have a boost gauge, watch it, keep it at or below 10psi any chance you get and watch your econ. go up.
Old 04-06-2008, 02:52 PM
Spamjohnson's Avatar
Spamjohnson
Spamjohnson is offline
pjp
Dude, St Cloud MN or FL?
What kinda mileage are you getting? Anything over 15 is gravy on winter fuel. 13 is probably more realistic depending on your driving.
I pulled 20 today, but that was crusing at 50 MPH.
Stock sized tires, while boring, will help mileage.
Running the climate control in face/off/floor will keep the a/c compressor from spinning. Make sure your front hubs are unlocked.
Other than that the other guys covered most of it. But remember, everytime you start the truck, the Exhaust Back Pressure Valve is activated to help warm the truck up, that eats about 4 MPG too.
Old 04-06-2008, 03:52 PM
Tim J's Avatar
Tim J
Tim J is offline
This is not a thread hyjacking....I just want to share this past trip with you.
Early 99 F-350 7.3L 4x4 CC SB SRW 285/75/16 BFG A/Ts, 4" straight thru muffler exhaust, 6637 and hypertech tuner at 90HP, Cabhigh Cap. Stock susp.
I got a chance to try an experiment this past week. My wife, baby and I went from NH to Harrisburg , PA tuesday. I filled up to the top of the filler neck just prior to leaving. I kept the speed to 70, at 2000RPM and used cruise. 460 miles. We took the same route home, however I had more fun...75-80. RPMs about 2500. Fueled to the top of the filler neck again. 14.6 MPG each way! I dont understand. But that's how it came out. I will continue to keep track of my milege.
Old 04-06-2008, 03:59 PM
powerstroke1869's Avatar
powerstroke1869
powerstroke1869 is offline
hmm that seems low for highway mileage i usually get around 18 on the highway and thats going 75 with cruise control
Old 04-07-2008, 11:19 AM
pjpandhisnewtruck
Thanks for the help!
Thanks for the advice and timely responses! 2x4 block made me laugh!
How about replacing the turbo? Heard that can add 3-4 mpg too.....
Old 04-07-2008, 11:22 AM
Spamjohnson
PJP, you can borrow my superchip programmer to try out, but would be better off with a DP tuner.
Old 04-07-2008, 11:26 AM
pjpandhisnewtruck
I'm in MN. DP tuner?
Old 04-07-2008, 11:33 AM
Spamjohnson
Do a quck search, basically, it is a computer program that can be switched on the fly for different performance parameters. It's part of a build up you can do if you want more power out of your truck, everyone says gauges 1st (pyro) then the DP. I didn't know about this site when I bought my superchip tuner. But wish every now and again that I had the DP.
I'm in Cloudy town too, so let me know if you want to borrow the Superchip, I just have to take the program out of my truck, so you can try it on yours.
Old 04-08-2008, 09:18 AM
pjpandhisnewtruck
Sam, that'd be great. Do you mind explaining how it works? When you say you'd take it out of yours, does your truck then run on the "old" factory settings or...? How long would it take for me to know a difference, per say??
Old 04-08-2008, 09:47 AM
03_PSD's Avatar
03_PSD
03_PSD is offline
Thats right, he would have to put the factory programming back onto his truck and then you'd be able to program your truck. You would tell an imediate improvement in performance. Don't really know how much it would improve your milage though, depending if you'd be able to keep your foot out of it.
Old 04-08-2008, 09:59 AM
nlemerise's Avatar
nlemerise
nlemerise is offline
Old 04-08-2008, 10:15 AM
Spamjohnson
PJP, let's take it offline, I'll send you a PM (private message)
