302 overheating
Old Jun 26, 2002 | 04:49 PM
herunar's Avatar
herunar
302 overheating
i got a 73 302 engine and it gets too hot. i have replaced the following: thermostat, radiatior, fan clutch with a flax fan, waterpump, bypassed the heater core, radiator fluid, and all hoses. it still gets hot. now, i have not tried eplacing the sensor or checking the guage (they are next on my list). but other than that, is there anything alse i could be missing.
thanks a bunch,
herunar
Old Jun 26, 2002 | 05:51 PM
BlueOvalRage's Avatar
BlueOvalRage
302 overheating
If the guage and sender check out OK, it is possible that you have a blockage in the cooling system, especially if it has not been well maintained over the years. A likely place would be plugged head gasket orifices. You may also be dealing with a blown head gasket or a cracked head.
Old Jun 26, 2002 | 10:47 PM
Mike W's Avatar
Mike W
302 overheating
I would first check with a good mechanical temperature guage. I have heard that blocks that have been bored will sometimes overheat but can't prove it. I had a 302 that would overheat at idle but was ok on the highway. You might check into a better water pump, different ones are out there.
Old Jul 7, 2002 | 05:18 PM
Old_Blue's Avatar
Old_Blue
302 overheating
I have a 79 F-150 that was doing the same thing. I had replaced the thermostat twice and the water pump once. I flushed it out and no matter what, it overheated. Knowing it couldnt be overheating, I replaced the gauge regulator on the back of the dash unit. Believe it or not that was all it was. All that work for a $9.00 push-on regulator.
Old Jul 8, 2002 | 05:43 PM
Sedric's Avatar
Sedric
302 overheating
I alway test a thermostat before I put it in. I've come across a few that don't work or work marginally. I just put them in a cup of boiling water and make sure they open up.
Other than that I would check the temperature sensor unit that screws into the intake manifold. Make sure it has a good contract between the threads for ground. Don't put teflon tape on the threads or it won't work right.
The other thing I have experience with is a blown head gasket that will cause overheating. You can tell if your coolant gets all foamed up.
Old Jul 8, 2002 | 07:22 PM
TorqueKing's Avatar
TorqueKing
302 overheating
exlabman
May 31, 2014 10:56 AM
bloydj
Jan 23, 2012 05:23 AM
old rat
Sep 11, 2011 09:17 PM
medicpg
May 19, 2008 07:27 PM
steve_
Bronco II
May 14, 2002 08:41 AM
