$10,000 engine?
Apr 5, 2008 | 06:51 PM
$10,000 engine?
Is it possible to spend that kind of dough on a engine rebuild?
Check out this 460 on
Its About Your Community - Home .
Click on features then classifieds then automotive.
Apr 5, 2008 | 06:55 PM
oh heck yeah... try blueprinting and building a stroker... if you need to send it away for any machine work, 10g's could end up being a down payment!!
Apr 5, 2008 | 07:00 PM
The 460 looks good. I have never rebuilt an engine so I was a little shocked at what the guy wanted.
Hey, Fomoko could swap this engine for that Chevy motor in his Roadster.
Apr 5, 2008 | 07:34 PM
o ya, ive got almost 4k into my flathead without all the internals and machining
Apr 5, 2008 | 07:40 PM
Oh yea, I saw that as well, The owner may have put that kind of money into it, but I wouldn't expect him make $10000 on it.
I'd rather go for the Ford Racing 514 Crate. ford $8000 Then again, I'd rather build my own, may cost more, but I'll get what I want.
Ford Racing 514 Specs:
Has Eagle® H-beam connecting rods M-6200-C514
625 HP @ 6250 RPM
600 ft./lbs. of torque @ 4800 RPM
9.8:1 compression ratio (nominal)
Sturdy 460 2-bolt main short block M-6009-D514
Cast nodular iron 4.300" stroker crank
Ford Racing forged aluminum dished pistons with full floating pins
Mechanical roller lifter camshaft with .647" lift, 254° intake and 258° exhaust duration @ .050" lobe lift
M-6049-SCJB “Super Cobra Jet” aluminum cylinder heads
M-9424-H429 “Victor Jr.” single plane intake manifold (requires Dominator carb)
1.73:1 ratio aluminum roller rocker arms
Apr 5, 2008 | 07:47 PM
Wow!!! look what I could do with my 460!! Just one problem, how do I get that power to the road? lol!!!
Apr 5, 2008 | 08:21 PM
Quote:
Originally Posted by
skidooman
BIG TIRES??
Apr 5, 2008 | 09:15 PM
HI and welcome aboard Eagle460. What is your Manitoba location?
No problem spending $$ on an engine, my 390 is mostly stock except for the 428 crankshalf which I already had, cost over $3,500 with all new internal parts and balancing.
Apr 5, 2008 | 09:17 PM
That 460 would probably tear my column shift three speed to pieces!
Apr 5, 2008 | 09:55 PM
Yeah its pretty crazy how much a guy can spend on a motor. The stroker I would like to build someday is gonna cost alot too. Will have oodles of power though, and I will robably only build an engine like that once.
Apr 5, 2008 | 11:02 PM
i'll have about 1200 into my 351w on just externals...
4:10 LS Marlon...
Apr 5, 2008 | 11:08 PM
I put 3200 into my stock 292 Y block.
Apr 6, 2008 | 05:11 AM
I think Marlon would have to go a little heavier than that. Maybe a 10.25 rear or Dana 70. Of course with big tires too!
Apr 6, 2008 | 08:48 AM
Older stock engines must cost a pile to rebuild.
Here i thought my 302 was a ton to get done!
Apr 6, 2008 | 09:26 AM
you can do a 302 for pretty cheap i've heard... common parts.
