GlowPlug Code and lack of power
Hello all,
OK I have done some searching and am getting all kinds of answers from simple to things I dont want to mess with.
I have a 2000 Ex with 145000 miles on it. the truck has started to show lack of power, long warm-up, rough idle and now I have glow plug codes. The other day I pulled a P0676 and a P0683 code and am wondering if this could cause the power problems.
I dont have any smoke out of the exhaust.
Any Ideas
Tanks in advance
Any Ideas
Tanks in advance
First off, welcome to FTE.
The glow plugs, whether they work or not, will not hurt your power. They only stay on for a max of a few minutes after first key on. The fact that you have GP codes could indicate you have a loose UVC harness and that would cause poor running. Check for loose plugs on the topside first. Also make sure you have good oil and it is up to level. Also a dirty fuel filter could cause rough running. Long warmups, don't know about that one. Boost leaks would also cause poor power perfomance.
Ahhhhh Mannn, New problem now the truck is having a hard time starting even with the heater pluged in. I have had this X for about 4 years and no problems. I am in So Cal so the temp here have been about 50deg or so. It is taking this thing about 15-20 min to warm up. If I do not let it warm up all the way it just compleatley looses power in the throttle. Yesterday It started reved up really high and the chuged down and died.
This problem is starting to worry me. Does this sound like an injector problem
Haven't got to use these in a while, May help locate what we are talking about.
