Sponsored by: Auxito
Need help Rear diff problem
Old Apr 5, 2008 | 12:40 AM
blacktop06's Avatar
blacktop06
I was doing axle bearings on my 03 supercrew 9.75. The two smaller gears that the pin holds in fell out due to dumb move on my part but now i cant get them back in.any one have any idea how to get them back in?????? thank you for any help.
Old Apr 5, 2008 | 08:16 AM
steve(ill)'s Avatar
steve(ill)
you need to turn the axle shaft slowly while holding the gear in place and it will roll it into position. you might have to put a short pin in oneside ,then roll the other gear in. maybe you can do them at the same time... might take a third hand.
Old Apr 5, 2008 | 09:14 AM
96f150's Avatar
96f150
Do you have Limited Slip? Maybe you have to push a little more due to the tension of the clutch packs? What d ya think Steve?
Rich
Old Apr 5, 2008 | 05:01 PM
blacktop06's Avatar
blacktop06
not working
i tried to slip the gears in but no luck any other ideas??? the washer on the gear slips off and it wont go. it is a LS in the rear.
