Manual 4x4
Old Apr 4, 2008 | 07:48 PM
OhioRiverCigarette's Avatar
OhioRiverCigarette
Manual 4x4
I would like to get a 7.3 diesel excursions with a manual transfer case. How many were made with manual cases?
Any common problems with the auto transfer cases
Thanks
Old Apr 5, 2008 | 01:14 AM
Monsta's Avatar
Monsta
Sit. Stay.
Exactly 0.
Only "problem" with the auto case is that the shift encoder motor can poop out. Largest problems stem from the stock hubs and owner's lack of maintenance on them.
Both cases are the same, sans shifting action. So one isn't stronger than the other...FYI.
Old Apr 5, 2008 | 10:49 AM
BobBarry's Avatar
BobBarry
Thanks
I imagine the electronically-controlled NV273 can be replaced by the manually-controlled version designated the NV271. Probably be easiest to grab the entire setup, including the floorshift, from a Superduty truck, and trace the floor cutout for the shifter from the donor truck.
dougegoble
Mar 24, 2015 03:15 PM
limptera13
WTB - Parts & other
Jun 20, 2010 11:40 PM
bIIcool
Bronco II
Nov 8, 2008 03:55 PM
yosemite
1978 - 1996 Big Bronco
Aug 30, 2002 03:59 PM
