Transmission Options
Old Apr 4, 2008 | 09:36 AM
deangelot1's Avatar
deangelot1
Well, not a huge fan of my 4 speed automatic in my 1997 F350 powerstroke. If I had one more gear that would be nice...I do a lot of pulling and it pushes into gear, especially up-hill, and I'm wondering what options I have for this transmission, because I do not think there are other tranny's for this truck.
Also, I thought about putting the 5 speek manaul in it, but I think there are differences in the cab that would make this difficult. Anybody have any idea?
And finally, what are the differences (minus the addition of the turbo) between the powerstroke (94.5-97) and the pre-powerstroke international 7.3?
Old Apr 4, 2008 | 10:02 AM
MADVAN's Avatar
MADVAN
Change the rear gear?
Do you have a 4.10 or 3.55?
Bill
Old Apr 4, 2008 | 02:39 PM
immastrokinnow's Avatar
immastrokinnow
i would be interested in putting the torque shift. (im sure they have some fancy way of spelling it) in mine. i really doubt this would be easily doable correct?i would assume it would be cheaper and easier to go with gear vendors overdrive?
Old Apr 4, 2008 | 03:35 PM
Cuda_jim's Avatar
Cuda_jim
Welcome to FTE
Changing the rear gear like MadVan says, would be the cheapest and easiest.
Look here for a bullet proof e4od auto trans (Big $$);
Brians Truck Shop
There are a few here that have made the swap from auto to manual, lots of work and get pretty expensive too. No changes in the cab from one to the other.
The biggest difference from 94.5/97 PSD's to pre-PSD's is horse power... bot are good IMO.
Old Apr 4, 2008 | 05:39 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The fancy way Ford spells it is TorqShift.
It would be cheaper and easier to buy a brand new truck with a TorqShift than to try and install one in your truck. An aftermarket overdrive would be A LOT cheaper!
Old Apr 4, 2008 | 06:48 PM
deangelot1's Avatar
deangelot1
Thanks for the welcome....I have 4.10 gears, and im gonna look into the gears idea...thanks
Old Apr 4, 2008 | 06:50 PM
deangelot1's Avatar
deangelot1
Im not quite sure about the torqshift thing, not sure if that would work? Would that be the entire tranny with an adapter plate, then you would have to change ECU????
Old Apr 4, 2008 | 07:37 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
I think that 4.10 is better than 3.55 for pulling.
Old Apr 4, 2008 | 08:11 PM
okfarrier's Avatar
okfarrier
Or even the 3.73 gears are better than 3.55's.
Old Apr 4, 2008 | 08:40 PM
Mark Kovalsky
You'd need an adaptor, then you would need to create a computer to run the trans. The stock one isn't going to do it.
mdh1701
15
Mar 19, 2017 09:41 AM
powerstroker100
Feb 14, 2014 08:59 PM
SolidCitizen94
May 14, 2013 02:20 PM
Junkyard Slug
Sep 2, 1999 09:15 PM
Junkyard Slug
Sep 2, 1999 01:15 PM
