got any hints for removing the intake on a 351w?? i got all the bolts off, its loosened, but i can't get it lifted off. feels like something is still holding at the back, driver side of the manifold... i've checked a few times now, there's no bolts there that i can see i missed...
Probably it`s just stuck down real tight on the gaskets, you can try gently prying on it in afew places to see if it`ll budge or there`s any movement at all. Sometimes it takes alot of force to break it loose.
Just be double sure you have ''ALL'' the bolts out. There`s been afew times I thought all the bolts were out only to find a hidden one or two.....
i'll do some more searching tomorrow... it puzzles me to no end. another thing is 2 lines, metal-like fuel lines, comming from the intake and were connected to the choke side of the old carb... are they exhaust temp lines to do with the choke system??
nice try Ryan... for now the 351 will suffice. i'd love a 300 build, but i'll take what i can get for now...
But really Sherm don't be too afraid of giving it a good yank, thoose gaskets get seated pretty hard. The first thing you'll hurt is yourself not the motor.
Another thing is 2 lines, metal-like fuel lines, coming from the intake and were connected to the choke side of the old carb... are they exhaust temp lines to do with the choke system??...
These lines supply hot exhaust air to kick the choke off.
What kind of intake did you get for your truck? We did the same mod on a 1985 351w HO and put it in our 79 F100, as well as a holley 600, headers, stacks, and msd ignition. We bought a Weiand Stealth intake.
thanks nathan/ryan, i guess i got to put a little more oomph to it...
thanks Fom, the new carb and intake is non egr, so that will be deleted...
i got the RPM air gap intake from edelbrock... heard good things about it, got a somking deal on it. how did yours go after the mods?? wake her up a pile??
Ya it sure did. A lot better throttle response, more torque especially at lower rpms, and it sounded 10 times better too. Of course it was drove like it added 200 more horsepower......
