Tire Size Help
Old Nov 22, 2011 | 03:27 PM
mattymack76's Avatar
mattymack76
Cosco , etc.... If you blow that tire you shouldn't be on that path.
Old Nov 23, 2011 | 10:01 AM
Skinsfan6's Avatar
Skinsfan6
Originally Posted by nunomad
Of all the researching I've done on tire sizes, why is everyone talking bout a 19.5" rim, of all tire companies I've looked at none offer a 19.5 tire, and if you have roadside problems like sliced or blown tire and it needs replacing, good luck finding a readily available tire to replace it with. Just my 2 cents worth, Nunomad
You're looking at the wrong tire companies. Look up rickson truck wheels where he got his from. They are commercial grade tires similar to those on tractor trailers. Very hard, thick rubber.
Old Nov 23, 2011 | 11:42 AM
mattymack76
Yes, it's not a car, or light truck tire.....it's overkill ... But I will say I drive my truck hard , tow, even some bad county and off road.... I don't worry about what I drive over
Old Nov 23, 2011 | 07:26 PM
the ponz's Avatar
the ponz
Originally Posted by mattymack76
Thanks! Like I said put tire and rims on and don't worry about them anymore! 34,000 still look new . I also did the door mod on here with the tubing..... Nice and quite in cab.
I am interested in your tire solution. What was your initial problem?
Does the truck ride like a buckboard when empty?
What tire pressures are you using?
Did you install the Goodyears or something else?
What is the part number for the rim you purchased?
Thanks. Great stuff. Now all we need is some photos.
Old Nov 23, 2011 | 08:24 PM
WE3ZS's Avatar
WE3ZS
I looked around some and found these pics Rickson Wheel Manufacturing
I think the fourth one down on the right might be Matts '04 EB EX, the name and location seem to be a good match. Some pretty cool lookin trucks there, I'm not too crazy about some of the more narrow tires but the wider ones look good. I've heard of folks getting crazy miles (100K+) out of these tires and of course the load rating overkill kinda makes the cost easier to swallow. My main concern would be how much stiffer the ride would get, I've already installed modded X & B codes and that has really firmed up the ride. I like how my EX rides now but these G or H rated tire may make the ride a little too harsh.
Old Nov 23, 2011 | 08:54 PM
the ponz's Avatar
the ponz
Would this tire set up be around $750 per wheel?
Looks really great.
I too would be concerned about the ride with the x/b springs.
Old Nov 23, 2011 | 10:37 PM
WE3ZS's Avatar
WE3ZS
Ponz, your question on cost got me thinking so I did some looking around. I figue if I was to upgrade tires/wheels I would be looking at OEM Ford 20" rims with the required $pacer$ and 285/60 tires. I compared that setup to the Rickson package.
Using prices from Rickson's website, Tirerack.com and ebay I just came up with these costs.
Rickson
19.5" x 7.5" powder coated steel rims = $285.20 (x4= $1140.80)
Michelin XDE2+ 285's = $484.10 (x4= $1936.40)
Stainless trim rings = $150.00 (set of 4)
Mounting and match balancing = $380.00 (set of 4)
I did leave out shipping as they are not far from me.
Total of $3607.20 ($901.80 per tire/wheel).
20" x 8" with 285's
King Ranch 20"x8" = $900.00 / $100.00 shipping (ebay)
Goodyear Silent Armor 285/60R20 = $376.00 (x4= $1504.00) (Tirerack)
Shipping for tires = $110.40 (Tirerack)
Wheel spacers = $640.00 (wheeladapters.com)
Mount and balance = $100.00 (estimated)
Total = $3354.40 ($838.60 per tire/wheel).
So the Rickson deal would cost me $63.20 more per wheel to start.
BUT I've seen reports of folks getting twice the miles out of these 19.5" tires compared to regular 'stock' tires. So if that is truely the case I would need to add the cost of a second set of the 20" tires to the equation.
Tires = $1504.00
Shipping = $110.40
Mounting = $100.00
Subtotal = $1714.40 add this to the original cost of $3354.40 for a total cost of $5068.80 ($1267.20 per tire/wheel).
In this situation the Rickson deal actually costs $1461.60 less than going to 20"s (counting the second set of 20" tires) thats $365.40 less per tire/wheel.
I've come to the conclusion that that is a crap load of money either way! And I'm glad my 16" stockers still have plenty of life left in them!
But it is worth more investigation to see if the 19.5" mileage claims are true.
Old Nov 24, 2011 | 11:15 AM
the ponz's Avatar
the ponz
Even though I am rather fond of Michelins, Rickson offers tires that could more than make up the difference between what they sell and the Ford 20" rim build.
I'm with you there.
the5schlueters
Nov 28, 2013 07:02 PM
iggybob44
Nov 12, 2013 05:25 PM
hanna5120
Sep 20, 2013 08:05 PM
LOP223
Jan 16, 2012 08:02 PM
TheWedge1
Apr 7, 2009 11:58 AM
