I am sure there are lots of close ratio top loaders in the trucks running around. I picked up a good one but after was told by a few that I wanted a wide ratio. Others told me no I was good with a close as long as I wasn't towing etc. I have a good 390, 3.53 gears and 25.5 tall tires. Tell me what you think...how does yours run? Thanks Brandon
Brandon as far as I know a close ratio transmission will have you shifting just the same as a wide ratio. The difference comes when you are towing which was pointed out. A close ratio will allow you to accellerate a tad quicker in my opinion. I wouldn't see any harm in running this tranny with the combo you have. I might opt for taller tires but that is it.
