rear differential
Old Apr 3, 2008 | 01:17 AM
danquin1's Avatar
danquin1
rear differential
can anyone tell me how to go about vhanging the oil in the rear diff of a 2000 expy EB 2x4?
Old Apr 3, 2008 | 01:22 AM
danquin1's Avatar
danquin1
also, sorry ...but can I do this in my garage? or will I need to put the truck on a lift?
Old Apr 3, 2008 | 07:20 AM
c_hohensee's Avatar
c_hohensee
You can do this without a lift. You remove the rear cover to drain, clean up the sealing surface and apply a silicone sealant as most do not use a gasket and reinstall cover. Refill with the apropriate lube ( I believe my 98 uses 75W140 synthetic) with friction modifier if you have limit slip to just below the fill plug.
Old Apr 3, 2008 | 07:52 AM
alwaysfords41's Avatar
alwaysfords41
If it is a LSD, make sure to add the friction modifier.
