engine upgrade
Old Aug 24, 2002 | 11:55 PM
don nm's Avatar
don nm
engine upgrade
I currently have a 1990 F-150 w/a 351/fi[junk] and I would like to put in a hopped up 390. will all the acc. bolt on the new block as they are the same size also will the A/C work as well also??
Old Aug 27, 2002 | 02:50 PM
speedking390's Avatar
speedking390
engine upgrade
If you get some brackets from a wrecker you can bolt it right up and yes the A/C should work just as well because the 390 turns the same way as the 351 so except for your computer you should have no problems
Steve
Ashes to AShes
Dust to Dust
Without ch*vs
our tools would rust
Old Aug 27, 2002 | 07:36 PM
Supercab's Avatar
Supercab
engine upgrade
This is interesting to me, I just bought a '94 F150, and was wondering if at a later date when my 302 dies if I could finally try an FE power plant, are you saying that frame mount supports from a mid 70s Fseries will bolt in????
Old Aug 27, 2002 | 07:53 PM
rodneyt28's Avatar
rodneyt28
engine upgrade
