Engine swap suggestions
Old Apr 2, 2008 | 07:34 PM
Voodoo66's Avatar
Voodoo66
I have recently bought a 1964 F100 with a 223ci and a 3 spd. i travel 80 miles to and from work everyday. i want an automatic trans but ant find a early C4 for the 223. Also Im bout to sell my dieselt o fuel cost and will be using the '64 to pull my Big block 6-71 blown '66 F100 to car shows. Now I have a 300 and a 460 i could put in the 64 which i have a c4 and c6 for the 300 and a c6 for the 460 i could use. Which would be the best for daily driving and great for pulling? Any uggestions would be greatly appreciated.
Old Apr 2, 2008 | 08:03 PM
camperspecial65's Avatar
camperspecial65
Just my opinion mind you, but I would guess the 460 would be worse on fuel mileage then a diesel...I would stick with the 6 definately...as for an auto that will fit behind it I dont know but I would definately keep hunting for one.
- cs65
Old Aug 19, 2009 | 12:01 AM
overlandexpress's Avatar
overlandexpress
I had a 4 speed 76 f250 2wd, the 300-6 in it was a great puller but it has no get up and go, like when it comes to passing or steep grades, I would have to shift into 3rd gear going up grades and it would do a steady 45mph and pull just about anything, (it had a 8 1/2 ft camper and I towed a 71 ford bronco all over!) it would just get down and go to work, if I was going to tow I would opt for the big block as the power would be great when towing and it would have good passing ability, you may suffer on the mileage with the 460, that old 300-6 got great MPG's.
Also I have heard that auto trannys behind 300-6's are gutless but I have no first hand knowledge on the subject.
knuckledragger66
Mar 31, 2012 08:17 AM
sleddog60
Apr 17, 2009 05:43 PM
64blue
West Virginia Chapter
Jan 29, 2008 09:31 AM
Voodoo66
Dec 19, 2007 09:52 AM
killerkjn
May 4, 2005 03:10 PM
