will it work? 351w
Old Aug 27, 2002 | 04:52 PM
nickc84's Avatar
nickc84
will it work? 351w
Hey guys,
I got a 86 F-250 2wd XLT with at 351W and a C6, the motor that I have in it now has got 3 piston skirts missing on it so its knocking badly. I've found a motor from a junkyard that someone has attempted to rebuild and couldn't finish it. What my questions are is, do I need a new flywheel or can the one off the 86 351w work? Do I need to change the harmonic balancer also? I have the block numbers to my best reading skills. Im getting the motor for $200 and I'm only going to need to put my intake on it cause its a 2barrel and mines a 4barrel. And my oil pan. The rest of the stuff I'll just have to change over on the motor like ac,ps,alt etc. But do i need a different flywheel or harmonic balancer? I think that It will all work but I'd just like some reassurance. Thanks guys
Post asap
D8AE-6015-ED23 Thats what i think it says.
Nick
Old Aug 29, 2002 | 02:35 AM
Quantrex's Avatar
Quantrex
will it work? 351w
All 351W's share the same 28oz balance weight, so you should be able to just swap parts over. The one question I have is the real seal. I don't know when (or even if) truck 351's switched to a one-piece rear seal. Sombody more familiar with truck motors will have to help you with that.
Old Aug 30, 2002 | 07:53 AM
nickc84's Avatar
nickc84
will it work? 351w
Its okay guys, I read the block numbers from the original motor that I'm taking out, and then compared it to the motor im putting in, and the numbers are both d9XX-6015-XXXX
so that means the oil pan will work because its the same block, what a relief that was to me. Thanks for your help guys.
Nick
Old Aug 30, 2002 | 09:11 AM
Bowed_up's Avatar
Bowed_up
will it work? 351w
restoringmy46
15
Jan 8, 2009 09:22 PM
jklennon
Nov 2, 2007 05:55 PM
butchf250
Feb 13, 2003 09:37 PM
Cowboy_billythekid
Jun 16, 2002 09:56 PM
Cowboy_billythekid
Feb 20, 2002 09:43 PM
