351w or 351m???
Old May 10, 2002 | 06:45 AM
1 eyed Jack's Avatar
1 eyed Jack
351w or 351m???
Hi,
I have a '79 F-150 with a 351, but I don't know how to tell if its a windsor or modified. Can someone help?
Thanks,
Jack
Old May 10, 2002 | 07:05 AM
1 eyed Jack
351w or 351m???
Sorry, I was just reading other posts and found the answer to my question.
thanks again,
Jack
Old Sep 3, 2002 | 11:01 AM
teschwab's Avatar
teschwab
351w or 351m???
the 351w uses a wet style intake and has a aluminum front timing cover. the thermostat housing bolts directly to the intake. the rocker covers are narrow and the oil sending unit is located to the left of the oil filter when viewed from the drivers front fender.
the 351m uses a dry intake. the thermostat housing bolts to the block instead of the manifold. the oil sending unit is located near the rear of the engine mounted about center of the intake manifold. the "m" has a cast in timing cover extention with a flat steel plate that covers the timing gear and chain. the rocker covers are wide when viewed from the the fender looking across engine bay.
hope this helps.
Old Sep 3, 2002 | 01:27 PM
loudfords's Avatar
loudfords
351w or 351m???
351Cleveland C4
May 28, 2014 12:46 PM
351Cleveland C4
Dec 31, 2013 01:24 PM
ohbrian
Sep 30, 2013 03:00 PM
jack wamp
May 11, 2012 12:09 PM
78ford351m
Oct 10, 2010 10:35 PM
