In the chart, the lowest number is 101 and the highest is 250, I'm not exactly sure but i would say it's atleast 200 if not 230-245.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Since the numbers improved when you put oil in there on your "wet" test, it's the piston rings at fault, not the valves.
