351w sd or maf
Old Apr 1, 2008 | 07:15 PM
ryan f150 4x4's Avatar
ryan f150 4x4
Talking 351w sd or maf
guys I have a 92 f150 4x4 zf 5speed 410 gears 33''bfg mts and a 302 the moter is cooked and i want a 351 I use my truck for pulling trailers and light offroading.What do u guys think how big a cam can i run befor i need to switch to maf and is it worth it .
I want to bore it 0.30 over some head work and a mild cam like pulling 4x4ing cam
Old Apr 1, 2008 | 07:33 PM
Conanski's Avatar
Conanski
You need a 5.8 ECU but the motor in my sig will run on an SD computer.
Old Apr 1, 2008 | 08:13 PM
ryan f150 4x4
Thanks Conanski can u give me a total list of parts .It would be great becouse Iam going to have someone do the moter work for me thankyou
Old Apr 1, 2008 | 10:01 PM
Conanski's Avatar
Conanski
I don't have actual part numbers and what you need will depend upon the machine work the block and rotating assembly needs. My block was bored 0.030" over and I used flat top pistons with valve reliefs for about 9:1 compression. The crank was good but some of the rods needed to be resized, after than it took stock size bearings. The cam bearing were also replaced, and I bought high quality rod bolts as well. You'll need the cam and lifters as well. I ported the stock heads myself and had the machine shop do a 3 angle valve job on the stock valves which were all reused. It's hardly worth putting new valves in these heads, if you are going that far pickup a set of used or rebuilt GT40 heads, then you're ahead of the game. Also consider that the World Products windsor heads for example are available for under $1000 brand new for the pair.. with valves and springs, and these out perform all the factory ford heads. It's all too easy to spend a lot of money on the heads at the machine shop, so get prices on replacements before you do anything.
Oh. by the way.. a 351 built like this KILLS the 302.. it's not even close, you'll definitely like this motor.
Do you have a complete EFI 5.8 for the swap? The 5.0 intake, distributor, and oilpan don't fit.. just so you know.
98powerstang
Mar 6, 2013 02:33 PM
FossenRacing
Jan 11, 2013 09:07 AM
hav24wheel
Sep 22, 2010 01:24 PM
justforkicks
Mar 25, 2009 09:33 AM
mikeyswood
Sep 8, 2005 03:46 PM
