4.9 injectors
Old Apr 1, 2008 | 05:02 PM
jonbass40's Avatar
jonbass40
4.9 injectors
Hello all. I got a quick question for you guys. I need a new set of injectors for my 89 f150 and I ran across this set. ACCEL 150615 - ACCEL Fuel Injectors - summitracing.com
Will these work good for a truck that only has an intake mod and headers and duals? or should i go to 17lbs? any help would be appreciated, thanks
Old Apr 28, 2008 | 03:16 AM
flipklos's Avatar
flipklos
the injectors in a 96 4.9 are the same as 5.0 injectors from the same year. you have to do the math to find out if you need larger injectors. a cold air and headers.... stock sould work. Id buy oem replacement
