vitals source?
Old Apr 1, 2008 | 03:05 PM
maniakmax1788's Avatar
maniakmax1788
Question vitals source?
Just needed to know where to hook up my 3 gauges. on my 1992 F250 351. 5.8
Oil pressure
Water temp.
Oil Temp.
thanks in advance.
Old Apr 1, 2008 | 04:19 PM
EPNCSU2006's Avatar
EPNCSU2006
For oil pressure, use a tee-fitting to tap into the stock oil pressure port in the block, near the oil filter. You may need an extension to give you room to screw in both the stock switch and the aftermarket sender.
For water temp, I just removed the stock sender on the driver side of the intake manifold (single wire sender) and installed the aftermarket gauge sender there.
To get a good oil temperature reading, you will need to mount the oil temperature sender in the side of the oil pan in a position where it will be submerged with oil even with the engine running.
