'94 F150 problem...need help
Old Apr 1, 2008 | 03:00 PM
samb926's Avatar
samb926
I'm new to Fords and just bought a 94 4.2L F150 manual transmission. When I press on the gas the RPMs go down and with a manual transmission it almost stalls it. What would be the best thing to do to try and solve this problem?
Old Apr 1, 2008 | 04:22 PM
EPNCSU2006's Avatar
EPNCSU2006
I would clean the throttle body and the idle speed control valve mounted on top of the throttle body as the first step. Use a cleaner that is labeled as safe for throttle body coatings. If this doesn't help, try pulling the codes from the computer (EEC IV Self Test hookup shows you how, using a paperclip and your check engine light), and check the EGR for proper operation.
