Distributor
Old Sep 2, 2002 | 08:05 PM
JPR's Avatar
JPR
Distributor
[updated:LAST EDITED ON 02-Sep-02 AT 09:08 PM (EST)]I need to put the distributor back in and I need to put the rotor on #1. Can someone let me know how to do it the right way.
Thanks Paul PS. ITS A 351 W.
Old Sep 2, 2002 | 11:42 PM
cajunbronco's Avatar
cajunbronco
Distributor
Pull the number one spark plug.Put your finger over the hole and have someone bump the motor over with the coil wire disconnected.When you feel a rush of air from thr cylinder stop.Now turn the crank pulley with a socket and line up the timing pointer with the 0 or TDC mark on the balancer.Install the distributor with the rotor pointing at or just past the number one terminal on the cap.This will get you close.If it is a EFI motor you will need to disconect the spout connector at the distributor and set the timing with a light.
Billy
Old Sep 12, 2002 | 09:21 PM
JPR's Avatar
JPR
Post Distributor
Thanks Billy now the dead 302 is gone and the new 351w is in it was real easy to find that set up.
Thanks Paul
Old Sep 12, 2002 | 11:03 PM
cajunbronco
Distributor
TJS96F-150
Escape & Escape Hybrid
Aug 24, 2011 11:24 PM
80351
Maryland Chapter
59
Jul 10, 2008 06:38 PM
Paul Welch
Apr 30, 2006 11:32 AM
PAUL_2
Mar 4, 2000 02:20 PM
PAUL_2
Dec 13, 1999 03:31 PM
