while i was browsing the tech folder, soaking up all the info i could, i noticed that every time i clicked on the following links it took me directly to ebay.
Instructions for changing your filter (Fuel): FUEL/WATER SEPARATOR DRAIN PROCEDURE
Thank you SBV45…
--------------------------------------------------------------------- And changing filter (Air) 6
Thank you SBV45…
--------------------------------------------------------------------- And changing oil CHANGING ENGINE OIL
Thank you SBV45…
--------------------------------------------------------------------- And Fuel/Water Separator Drain Procedure FUEL/WATER SEPARATOR DRAIN PROCEDURE
Thank you SBV45…
--------------------------------------------------------------------- Battery Disconnect —Dual Battery Disconnect - Dual
Thank you SBV45…
--------------------------------------------------------------------- Torqushift Shift Relearning Strategy Torqushift Shift Relearning Strategy
Thank you SBV45…
i was just wondering if anyone else was having that problem!
Everything is being addressed since the change over is not complete. Be patient.
I'm sure alot of others are feeling like me and would just like a little info on what is happening rather than wondering if all our photos have been lost.
I figured it had to do with the site work yesterday but never saw any info about it.
Nothing is lost, at the top of the forums (Post by Cars2007) it explains what most important is happening now. Be patient, FTE is pretty big site to overhaul in a short time.
If you click on the links in the Tech Folder, they work now.
i just tried to click on the link in the tech folder and i still get ebay. it doesn't matter to me because i can get to them from this thread but for someone who doesn't know about it might get a little frustrated. i'm not trying to hound on this i just thought i would try to help keep this the best site on the web!
Try clearing your browser cache... It may now just be your PC going on "bad" history. Another thing to try is this:
go the the tech folder
press <ctrl> Ctrl & F5 simultaneously to refresh the browser footprint of the tech folder</ctrl>
I still get redirected to ebay when I click on any of the links in the tech folder. I deleted all cookies and temp files and I still get redirected to ebay...can anyone advised how to solve this problem, or is the site still partially down?
Thanks
Dave
I also tried what ozx3+1 advised and I'm still getting redirected to ebay...
Thanks
Dave
It's odd and telling that all of the links in question are under this directory structure: Index of /s/b/sbv1/Procedures
Click the link and have a look! There's a redirect issue somewhere in the FTE handlers from within the tech folder... The question is, where does it turn up-side-down and catch fire?
ozx3+1
I clicked on the link in your previous post and I was able to get to the link I needed (fuel filter change). I will just use that link you posted until they hopefully work out the bugs.
