'70 heads
Old Mar 31, 2008 | 06:12 PM
9299Fords's Avatar
9299Fords
'70 heads
I haven't heard anything about these heads from 1970 351w - DOOE-C or '69 oe-c
I read that they are better flowing than the GT heads. Anyone know about them?
Old Mar 31, 2008 | 07:39 PM
quicklook2's Avatar
quicklook2
had a set on my 70 ranchero gt.
they were already ported and polished when i bought the truck but they were supposed to be the best ones to start with.
Old Mar 31, 2008 | 10:24 PM
9299Fords's Avatar
9299Fords
Not a bad vehicle to have. Good info on the heads. Thanks.
Old Apr 1, 2008 | 06:11 AM
bad96's Avatar
bad96
i havent heard anything about them, but id ask down in the small block V8 forum
Old Apr 1, 2008 | 08:02 AM
Conanski's Avatar
Conanski
The early 351 heads are a good candidate for a low budget DIY porting job, they have slightly larger valves than the later castings so they will flow more when ported. The '90's GT40 castings are a better flowing head before porting however, and have more potential with porting.
Old Apr 1, 2008 | 04:18 PM
9299Fords's Avatar
9299Fords
Thank ya sir! I guess I'll keep looking for an affordable set of GT40's. In my searching for 40p info, it looks like the p's flow a bit better than the standard GT40. Does anyone know of a set of headers that are compatible with these heads that do not need dropped everytime you change the plugs? Can you mill these heads .030 for higher compression without problems?
