Take two
Old Mar 31, 2008 | 06:08 PM
Edigan's Avatar
Edigan
Take two
I posted this in the wrong section earlier, so I'll try it again here.
Hello everyone. At work tomorrow, I am going to work on a 6.0 diesel. I got a code P0263 and P0269. The truck runs ok when it is cold, but it runs terrible when it warms up, and it will eventually die. It sounds to me like a high pressure oil o-ring is bad, but what do you think?
Old Mar 31, 2008 | 07:46 PM
Maxium4x4's Avatar
Maxium4x4
Is the truck an 05?
Old Mar 31, 2008 | 08:11 PM
bismic's Avatar
bismic
Cylinder #1 and cylinder #3 contribution/balance:
When maximum/minimum pulse width adder is exceeded and cylinder does not converge, a fault is set.
hopefully someone else can interpret...............does this mean injector problems or could it be HPOP related as OP indicated?
Old Apr 1, 2008 | 03:12 AM
Edigan's Avatar
Edigan
The truck is a 2003. We have another just like it, and I just finished changing the ICP sensor and harness. That wasn't much fun.
Old Apr 1, 2008 | 09:46 AM
Maxium4x4's Avatar
Maxium4x4
Check for low fuel pressure. Measure the fuel pressure at the engine filter housing test port, should read between 45-58 psi
Old Apr 1, 2008 | 10:43 AM
johnperdeye's Avatar
johnperdeye
egr valve....mine did the same
LARIAT 85
May 12, 2009 04:28 PM
rat49f6
Apr 4, 2009 09:22 AM
fordxlt150
19
Mar 16, 2009 10:55 PM
SilverDcab
All Things Towing
Jan 29, 2009 06:00 PM
