Re-Using Head Bolts
Old Mar 31, 2008 | 03:20 PM
dustinova's Avatar
dustinova
Re-Using Head Bolts
I'm getting ready to swap the 460 into my 78 F-250, and I have a question regarding the head bolts. I'm going to be replacing the head gaskets while I have the engine out since I saw some white smoke when I ran the motor. Can I re-use the head bolts that I take off the motor? If not, where could I get a decently priced set (stock replacements)?
Old Mar 31, 2008 | 07:31 PM
greenhighboy's Avatar
greenhighboy
You can reuse them.
Old Mar 31, 2008 | 11:00 PM
mwvdub's Avatar
mwvdub
I have always just hit them with a wire brush and re used them with out any troubles.
Old Apr 1, 2008 | 01:02 AM
DanielC's Avatar
DanielC
service manual
If you can get access to a service manual it will have the answer in it, Probably you can, modern engines use torque to yield bolts.
Chase the holes the block with the correct sized tap so the bolts thread into a clean hole. A thread chasing tap would be ideal, but if you cannot find one, a bottoming tap will do. Try to find a used tap, if you cannot get a chase tap. It will cut less metal fron the threads.
Old Apr 1, 2008 | 02:16 AM
Bear 45/70's Avatar
Bear 45/70
Not the 460 engines. It was designed in the late 1960s. That's not modern by anybody's standard.
Old Apr 1, 2008 | 02:31 AM
Dirt racer's Avatar
Dirt racer
I always cleaned them up and reused them with no problems.
Old Apr 1, 2008 | 09:26 PM
69-highboy's Avatar
69-highboy
The 1/2" head bolts used in the 385's are tough and certainly can be reused. That said, if I were building a rod I'd go for new bolts, otherwise don't worry about it.
Old Apr 1, 2008 | 09:36 PM
bad96's Avatar
bad96
i just reused mine an upper-end rebuild!!!! hit them with a wire wheel and like was said chase the holes with a tap
