FL-820S Gasket Failure
Old Mar 31, 2008 | 11:42 AM
johntucker09's Avatar
johntucker09
I usually change my own oil...when I took the oil filter off, the gasket fell into my oil collection pan...I took it and cleaned it up, it was cracked in 5 places...I was just wondering if anyone else has had this problem.
Old Mar 31, 2008 | 12:55 PM
Twinsdad98's Avatar
Twinsdad98
I've never had that problem and I also use the Motorcraft filter. Do you run some oil around the gasket before you install the new filter? Just asking...
Old Mar 31, 2008 | 01:04 PM
mercman86's Avatar
mercman86
I've seen this problem (not on any ford fl-820s) before. from what i can tell this usually happens if oil isn't put on the seal before the filter is installed. Also if the filter has been on the motor for a long time it could dry rot from the outside. overtightening the filter (using a filter wrench to tighten it) could also cause this problem.
Old Mar 31, 2008 | 01:18 PM
johntucker09
I'm usually pretty good about lubing the oil filter up before I install it...it is probably just a matter of over-tightening...I had had surgery on my right hand (my primary hand) and wasn't confident that I had gotten it tight so I used a filter wrench (which I only keep to get the filter off) to make sure it was snug...I guess I got it too snug.
larrymul
Dec 24, 2014 04:03 PM
mrad
Jul 4, 2014 12:44 AM
Partime
Jun 28, 2013 09:39 AM
onebadb1
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 7, 2010 11:15 PM
