i have a 96 302 and trans out of a f150 4x4 that i want to put in a 99 ranger 4x4 can anyone point me in the right way for headers, oil pan, motor mounts, and everything else ill need to do the swap. both trucks are auto and 4x4
<TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">It needs either a double hump or rear sump oil pan, so I think your existing pan will work, Headers, summit sells them or else I used 79-93 mustang long tubes with a little bit of pounding. Motor mounts, 4.0L ones from your ranger will bolt together with the F150 ones I believe. I built my own</TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
</TD></TR></TBODY></TABLE>
To make engine mounts use 4-5mm steel, bent and weld...
I usually look for front x-member on j-yard (there are many damaged in accidents x-members with bent lower controll arms) and fit them to it. Much easier to work then on truck on a pit. And when engine mounts and engine fit x-member I put engine into a truck, and then I install tranny do measurments to make tranny x-member.
just look up and buy the ranger v8 swap kit. its what i did and comes with new mounts that just bolt up, new radiator, headers, oil pan, oil pump, and it moves your oil filter so things fit nice all up under the hood
that is where i bought my kit from. kind of pricey for sure but you almost reach that buying individual prices. like i said earlier this kit for the 302 came with
new double sup oil pan, new headers, rubber motor mounts (which i was told buy everyone to make sure to get), new oil pump, new radiator, a system to move your oil filter out of the way.
i got my headers and oil pan chromed and the motor mounts are supposed to just bolt directly up to the truck and the engine no fabrications what so ever.
if that site doesnt work i went to yahoo and searched "V8 ranger conversion kit" and clicked the second choice "car shop 38200......."
